why?? (rant/question)
Old Mar 24, 2006 | 06:54 AM
cowboyty's Avatar
cowboyty
I have seen a car (hot rod) and its engine compartment is cover with polished aluminum. Helped the guy change plugs and wires only to fine the polished aluminum was road signs cut up and buffed the backside to a shine.
Old Mar 24, 2006 | 10:40 AM
fordraceboy's Avatar
fordraceboy
i'd go to headers.... lol that is sponge between the tranny and floor and it is factory..
Old Mar 24, 2006 | 12:09 PM
Mil1ion's Avatar
Mil1ion
Actually the A stand for LARGE Ford car not necessarily a Galaxie.
In this case the A is a Galaxie because of the year.
Oh,,,, the C6 is NOT 68......It is 66.
(It could possibly be used on a 68 though.)
That means the part was designed for a 1966 Large Ford car and the E means it was designed by the Engine (ering) division of the company
That digit (3rd) stands for what vehicle the part was designed for not what vehicle it could actually go in.
FORD make their numbering easy for us.
I memorize most of my numbers as well but occasionally I go here to for a refresher.
http://www.fomoco.com.au/part%20number%20codes.htm
Always remember this as well.
There is a difference between Casting Numbers & Part Numbers.
A part can have a casting number but it also has a different PART number when ordering.
Old Mar 24, 2006 | 03:08 PM
76 F-150 390FE's Avatar
76 F-150 390FE
i want to go to headers but i have NO money at all and i definately dont have $300 for headers and $200 for an exhaust.
Old Mar 25, 2006 | 12:13 AM
lscolonel's Avatar
lscolonel
There are two sets of factory headers on ebay right now but they want more for them than I just spent on aftermarket ones.
Old Mar 25, 2006 | 02:14 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
If you have a friendly Ford counter man, with a little time to spare, he can look up parts for you using enginering or casting numbers. It can take him awhile though.
I did this once to help a guy on this forum looking for a part number for his hood ornament with three lions on it, to see if it was factory or added on later.
The casting number brought up about 10 different hood ornaments ranging from the Explorer over world 1975 hood ornament to a 1981 Explorer black hood ornament, to a universal hood ornament for the 1973 1979s. All those parts share the same casting part number.
You then have to cross reference those 10 hood ornament part numbers, to get the part number you need, or the part you want.
As I said not all parts men would take the time, but they can do this.
In some instances however a casting or engineering number may bring up 1000 or so parts, fitting several different vehicles. and a parts man may not deal with that too kindly.
Still with the hood ornament, didn't figure out what trim line it belonged to, but we did find out it was made for his truck. Probably an option extra etc...
hope this helps
Old Mar 25, 2006 | 03:39 PM
76 F-150 390FE
just got back from the yard again, told him my problem, pulled out a wad of cash and gave me the money back. he said i aint sure if i have one i dont think i do but you can go up the hill behind that bus and look. i went up there and there were stacks of manifolds so i started diggin. after about 10 mins i came out with one. same exact casting number. one of the stud holes needs to be drilled and tapped bout other than that it is good. went back down there handed him back the money he gave me earlier and walked out.
Corkwheats
Jan 19, 2013 10:39 PM
BigF350
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
Nov 6, 2012 04:44 PM
bomberboat
Nov 7, 2008 07:37 PM
the_binbuilder
May 15, 2004 01:30 PM
rayray2k22002
Jul 31, 2002 12:41 PM
