what is a 5.8 HO??
Old Mar 29, 2006 | 08:31 AM
uncle junk's Avatar
uncle junk
hey by the way edelbrock thunder series avs 650cfm is the carb i run. really almost a bombproof carb and if im not mistaking it for something elese i was also told you can get the 650 cfm avs in a dual feed correct me someone if im wrong.
Old Mar 29, 2006 | 09:06 AM
nwmud's Avatar
nwmud
well I been pricing and both carbs cost about the same, unless someone knows of a sale. this truck is not running a 351W HO, rather an old worn out 351W currently with a Holley 2300 from my Scout II.
Just last friday, I got a call "the truck won't idle" it keeps stalling.
so I found a missing vacumm hose causing a leak. that was not it.
Turns out it had 2 major vacumm leaks and the power diaphram on the carb was leaking. so I replaced it and while I was at it - installed new motorcraft spark plugs. the truck is currently running great. BUT not good enough I would go off road with it.
Still looking forward to a rebuilt engine and a more reliable fuel system.
Ritch
Old Mar 29, 2006 | 09:10 AM
uncle junk's Avatar
uncle junk
rich also edelbrock cam and lifter kits with the aluminum intake are also a great fairly low cost add on items to look at i run the perfomer series and i love it
Bobcat7
21
Mar 23, 2025 03:03 PM
TheTowingCowboy
Modular V8 (4.6L, 5.4L)
19
May 6, 2020 02:39 PM
Krisverde
Aug 19, 2015 01:06 AM
umdstang
Oct 19, 2004 06:18 PM
Franklin2
Mar 6, 2002 07:49 PM
