302 vs 351 E7TE Heads
Old Mar 28, 2006 | 05:11 PM
bivens1172's Avatar
bivens1172
Other than the bolt holes is their a difference between 302 E7TE heads and 351 E7TE heads?
Old Mar 29, 2006 | 08:36 AM
uncle junk's Avatar
uncle junk
when you say bolt holes do you meen the bolt pattern that mounts the head to the block is different .so a head from a 5.0 e7tes wont mount to a 351w cause i was going to put a set of e7tes on my 351w and im not sure what they came off of ill have to check
Old Mar 29, 2006 | 09:39 AM
Kemicalburns's Avatar
Kemicalburns
they are swappable heads but 5.0 heads to a 351w will require drilling out the head bolt holes to 1/2 size. take them to a machine shop to have this done. otherwise they are the same head.
CoyoteBevel
Arizona Chapter
Dec 1, 2017 09:26 PM
rooster41
New Member Introductions
Aug 26, 2009 03:01 PM
cujo8
May 19, 2006 05:12 PM
lisagoud
Oct 15, 2004 04:24 PM
RanDawg
Jan 29, 2003 09:22 PM
