what is a 5.8 HO??
Old Mar 22, 2006 | 01:29 PM
nwmud's Avatar
nwmud
what is a 5.8 HO??
I was calling around the other day for rebuild shops and they quote me 2 prices.
I have a 1982 Ford Bronco - full size. It had a 5.0 in it but we put a 5.8 from a 1983 van a few years back. so anyway.
what is the difference between a 351W (5.8) and a 351W HO (high output) ???
Ritch
Old Mar 22, 2006 | 02:31 PM
loudfords's Avatar
loudfords
351W HO was a 4 barrel offered as an option in 84 & 85, standard in 86 & 87. Had different intake (obviously) and cam than the 2 barrel, possibly the heads were different too?
Old Mar 22, 2006 | 05:55 PM
pfogle's Avatar
pfogle
Heads were the same, the cam was a little more agressive. I also came with a holly 750cfm 4bbl.
Old Mar 22, 2006 | 06:14 PM
nwmud's Avatar
nwmud
so is there any reason I cant put a 4 barrel on a NON HO engine? Just because it came with a 2 barrel carb - does not mean I want to run a 2 barrel carb.
I am looking at putting a Holley Truck Avenger 670 CFM.
My buddy has provided me with a Holley center hung 750 and says it will run just as good as the truck avenger if not better on the hills and such when wheeling... But I want the truck to run like if just left the factory. She had very little trouble with stalling and such when we got the rig. But I messed up and dropped in a 351W that was not in as good of shape as i was thinking it was and have never got it to perform as well as I promised her.
So a new rebuilt is in her future. I am just trying to find out what carb to run to give her the most bang for her buck. and We have talked about going EFI - but that is not in the cards.
A buddy said I should skip the RV cam for the engine and just keep it all stock so if she ever does go EFI someday - I wont have to worry about the computer coughing at the cam.
Thoughts and ideas????
Ritch
baddad457's Avatar
baddad457
I doubt it was a Holley 750, more likely the same Holley/Motorcraft 600 that the Stangs got.
Old Mar 22, 2006 | 06:17 PM
baddad457's Avatar
baddad457
Most bang for the buck is buying a Holley 500 cfm 2 bbl and bolting it onto the stock 2 bbl intake. 4bbl performance in a 2 bbl package. And that's with a new carb, even more bang by buying a second hand 500 , kitting it if needed and then bolting it on.
Old Mar 23, 2006 | 09:11 AM
Kemicalburns's Avatar
Kemicalburns
i wouldnt run a holley on a 4wd at least not the older models. they flood easily when bouncing around and blow power valves left and right. most need modifying to perform well in a 4wd application. i hear the truck avenger though is a good carb and doesnt have these issues.
Old Mar 23, 2006 | 02:36 PM
nwmud's Avatar
nwmud
I am not following your comments. a friend gave me a holley 750 to put on the truck. I did not say it came from her truck.
As far as putting a Holley 500 2 barrel on a wheeling rig - no chance of making that kind of mistake again. Like Kemicalburns said - they are not great off road carbs. she is currently running a holley 2300 carb and has been for about 2 years now. it was completely rebuilt and ran purfect when I put it on her rig. but now she has very limited hill capability. Of course we might be pushing the limits of angles even for a truck avenger carb. But it has got to perform better with a new rebuilt engine and a well working fuel system.
I have heard and read good things about the Truck avenger carb and that is one of the reasons I am asking questions about using it for my application. Yes the truck is a daily driver BUT she does like to go off road and she ain't no pansy - she plays pretty hard and has a truck that shows all the signs of being a true off road rig.
Ritch
Old Mar 23, 2006 | 07:22 PM
baddad457's Avatar
baddad457
Only thing different Holley does with the Truck Avenger is install vent slosh tubes and jet extensions. Both are easily done to std Holleys with side hung fuel bowls.
Old Mar 24, 2006 | 01:32 PM
nwmud's Avatar
nwmud
then it would appear a center hung would work better on hills and such. Its not like doing circle track where you are alwas turning in the same direction.
Old Mar 24, 2006 | 04:21 PM
baddad457's Avatar
baddad457
You'd think so, Shelby was the first to try the center hung bowls back in the 60's for road race applications.
Old Mar 24, 2006 | 11:03 PM
oldmansimek's Avatar
oldmansimek
The holley truck avenger is not that good and like all holleys needs to be messed with all the time and every time the seasons change. I got rid of mine and bought the new Edelbrock off road thunder and have not touched it since. It was cheaper and definitly handles hills and everything for that matter noticeably better. I would not go with a 750 that is way to big. try a 600 or 650 at max if your going with either off road carb.
Old Mar 25, 2006 | 07:57 AM
baddad457's Avatar
baddad457
You're sadly mistaken here. Holleys do NOT need to be "messed with" when the weather changes. NONE of mine do. Tune it properly and then LEAVE IT THE HELL ALONE. It's more likely the rest of the engine is out of tune, or you're running crappy fuel with no filter. If you have to keep fiddling with a Holley, that's just a sign that you don't understand them to begin with.
Old Mar 25, 2006 | 08:52 AM
oldmansimek
Engine is not out of tune and I run vp or 93 I use my truck off road alot and the holley was not up to the challenge.
Old Mar 29, 2006 | 08:22 AM
uncle junk's Avatar
uncle junk
i run alot of edelbrock carbs on my rigs and they seem to be trouble free compairded to the pile of junk made by holley for motorcraft by the way on a 351w ho they were 650 cfm and any one who wants to doubt it ill mail you one and you can read the cfm for your self i got a pile of them waiting to go
