Any boby know anything about a c-8 transmition.I have a transmition pull out from a 78 it is a automatic transmition a the # read like this 1 124c8 77131.
Aloso I wander if is posible to run a cruss control form this 78 that I have into my 77 c-6 tansmition, I know that the harnes has to pull out, so the cruss controol can work on mi truck I thik I have every thing I need to do the change. but I don't know if is goint to work with my trans.
To verify which transmission it is, check the drivers door post for the trans code. According to my Chilton's manual, here's what the codes represent for 73-84 models.
C4=G
C5=W
C6=P (73-82) K (83-84)
AOD=T
FMX=J
I think the 78 truck has a over drive transmition, becuse has original crus contro.
What is the difference on a c6 and a FMX trans. other than the hydraulic pan.
Thers any thing in particular I may be looking for, the rating plate on the truck show on the trans box a '' G'' is that a c-6 trans or a FMX trans.?
G = C6 automatic transmission. Always check the bolt pattern and pan shape as discussed on previous post to make sure nothing was swapped prior to you buying the truck.
