electrical problem
Old Mar 23, 2006 | 09:05 PM
scrapyardking's Avatar
scrapyardking
electrical problem
I have a 77 f-250 and hears whats going on.. whenever I turn on the head lights the left turn signal arrow in the dash stays on all the time and the turn signal light on front of truck is out. but when I go to use the turn signal the outside light blinks. Can anyone help me on this.
Old Mar 23, 2006 | 09:07 PM
cheez67's Avatar
cheez67
check your grounds for your lights.
Old Mar 24, 2006 | 02:29 AM
Craigster1's Avatar
Craigster1
Try this. On the turn light that “glows” inside and is weak outside, install one end of a jumper wire from a good ground and the other end under the small ground tab. The small ground tab is outside of the light socket under the foam gasket. Carefully bow out the flat spot of the tab and stick the jumper underneath. I chased this problem for years and finally found it.
If you find this works do all four corners
Old Mar 24, 2006 | 02:48 AM
dakonthemountain's Avatar
dakonthemountain
After you check your grounds, try replacing the socket on the turn signal on front of your truck. I had the exact problem you describe and found out (on this website) that the sockets actually can go bad. I replaced it and all is well. Good luck!
Dak
Old Mar 24, 2006 | 03:23 AM
jimmieg2's Avatar
jimmieg2
check the ground behind the side marker light as well it is connected to the head lights as well as the tail lights
Old Mar 24, 2006 | 08:53 AM
wintremute's Avatar
wintremute
I agree bad ground. I had these problems constantly after I first bought the truck and it was always a bad ground.
Old Mar 24, 2006 | 10:49 AM
Craigster1's Avatar
Craigster1
I should have mentioned that the jumper wire method (above) supplies the ground by going around a bad connection inside the socket. All of my sockets have the same problem but at $15 ea I found a better place for the $60.
Old Mar 24, 2006 | 10:53 AM
amish77's Avatar
amish77
good call craig. I hadn't heard of that one. Everyone else just sez replace the sockets. Fixing the error that ford made is definately the eay to go.
Old Mar 24, 2006 | 12:22 PM
Mil1ion's Avatar
Mil1ion
Carig & I like to save money therefore we both suggest trouble-shooting before wallet emptying (replacing parts).
What I don't understand is so many people have spent $ hundreds for something that may have been a broken wire.
Then they say;" It was running badly before I replaced parts".
Old Mar 24, 2006 | 02:38 PM
rmalottwtes30's Avatar
rmalottwtes30
I had somewhat a similar problem, the problem was the license plate light socket. Try that.
Duke78
Jan 17, 2010 04:58 AM
fromm
Electrical Systems/Wiring
Mar 8, 2009 09:04 AM
FatBrian
Oct 16, 2007 05:58 AM
ranger429
Aug 26, 2003 03:39 PM
