Headlight Switch
Old Mar 21, 2006 | 02:51 PM
btacarlton's Avatar
btacarlton
So even thought the manual has #961 listed as ground, it is actually power for the dome light? How would I incorporate the door jamb switches into the mix?
Old Mar 21, 2006 | 02:52 PM
1975Ford's Avatar
1975Ford
to dome light ground wire - 961 - negative power out to dome light - black 18 guage wire
Old Mar 21, 2006 | 03:04 PM
btacarlton's Avatar
btacarlton
Ok, last question and I will stop bugging you about this. Do I connect #961 to the D2 terminal on the switch?
Old Mar 21, 2006 | 03:22 PM
1975Ford's Avatar
1975Ford
Dome Light (D1 & D2 terminal on Headlight Switch)
Two options to wiring the dome light, for the
Option 1 (I recommend this setup)
D1 - ground to head light switch light - supply a negative power directly to head light switch - black 18 guage wire.
D2 - to dome light - 961 - from head light switch to dome light - black 18 guage wire.
-945 - 18 guage white wire - direct positive feed to dome light and interior lights from fuse panel.
Negative power main feed thru door switch, when door switch triggered, it will supply negative feed to dome light and interior lights and light bulbs will glow.
Or negative power for dome light switch will make light glow when switch is triggered.
Old Mar 21, 2006 | 03:32 PM
1975Ford's Avatar
1975Ford
yes, connect # 961 to D2 terminal on headlight switch.
I enjoy electrical work, keep the questions coming.
Old Mar 21, 2006 | 03:43 PM
btacarlton's Avatar
btacarlton
Thanks for all your help. And I just might have more questions down the road.
Old Mar 21, 2006 | 03:58 PM
1975Ford's Avatar
1975Ford
-continued Dome light- (Option 2)
Option 2
D1 - Positive "+" power to head light switch light - 945 - positive power directly to head light switch - white 18 guage wire.
D2 - to dome light - run a new 18 guage wire for positive feed - from head light switch to dome light and interior lights - white 18 guage wire.
-961 - 18 guage black wire - direct negative feed to dome light and interior lights.
Positive power from - 945 - thru door switch, when door switch triggered, it will supply positive feed to dome light and interior lights and light bulbs will glow.
Or positive power for dome light switch will make light glow when switch is triggered
Old Mar 21, 2006 | 04:06 PM
btacarlton's Avatar
btacarlton
Thanks again for all the help.
ved0303
Jul 11, 2014 04:51 PM
kcm712
Mar 6, 2011 07:09 PM
drewk4
Jan 31, 2010 01:04 PM
crzycrazycarl
32
Feb 22, 2009 08:53 PM
