Headlight connector location
Old Mar 6, 2011 | 04:17 PM
kcm712's Avatar
kcm712
I Have a H.I.D. headlight kit I want t install and i was wondering if anyone knows where the three prong connector is for the headlights? The H.I.D. system has a connector from the controller that needs to plug into spot on vehicle. Thanks. (2007 Expedition EL Limited)
Old Mar 6, 2011 | 05:01 PM
Moto Mel's Avatar
Moto Mel
If you have the correct kit it should be a plug-play install. The kits come with a ballast thet supplies the power to the bulbs. The kit that I bought for my Mark VIII was very easy to install and I'm buying 2 more for my wife's 'Sploder and my Navigator.
Old Mar 6, 2011 | 06:00 PM
kcm712's Avatar
kcm712
Thanks, Mel. I believe I have correct kit, but need to know where the connector for the headlights on the vehicle wiring harness is. I see where all other connections are such as bulbs and power and grounding. The kits control module needs to be plugged in to vehicle headlight wiring harness.
Old Mar 6, 2011 | 07:09 PM
thecardoc's Avatar
thecardoc
Look at the back of you 9007 bulb . Do you see the plug that plugs in to that bulb . Well that is the plug you are looking for.
Tank2009
2009 - 2014 F150
Dec 9, 2016 01:44 PM
Tank2009
2009 - 2014 F150
Dec 9, 2016 01:05 PM
Marauder92V
6.7L Power Stroke Diesel
Dec 6, 2010 04:14 PM
tolliewolly
Oct 14, 2010 11:41 AM
vrsc
Jan 16, 2010 02:21 AM
