Another Hellwig Rear Sway Bar Question
Old Mar 19, 2006 | 06:54 PM
fuelmover's Avatar
fuelmover
just received my sway bar from JCW, and it has a tubular end link that drops down from the frame. Most discussions/pics here show a set of end link plates that bolt together.
Does anybody know what gives? Did I get an old design?...new design?
I haven't had a chance to fit it up to the vehicle to see if the tubular end link is the correct length.
My X is a 4x4, but assume that doesn't matter since the Hellwig site shows the same models number (7643) for 4x2 and 4x4.
Thanks in advance for any info.
Old Mar 19, 2006 | 07:50 PM
aklim's Avatar
aklim
I think you are fine. You need to put the bushings in place first. Use a little grease and a piece of wood and a mallet. Those get put in the frame with the big bolts. Then you will have that screw section hanging down. Slip the metal sleeve on it and hold it there with a washer and a bushing. Insert the screw end thru the sway bar followed by another bushing and washer and a nut.
Old Mar 20, 2006 | 08:46 AM
SledHauler's Avatar
SledHauler
I'm not sure if it's new, old, or different...... but mine from Summit has the tubular links as well and is working great.
Old Mar 20, 2006 | 10:02 AM
aklim's Avatar
aklim
I talked to Hellwig and they said it was the newer version. The older ones were square the newer ones are tubular. Hope that clears it up.
Old Mar 20, 2006 | 11:52 AM
fuelmover's Avatar
fuelmover
Thanks for the info. I did crawl under the X just now and held the link up to the frame. It appears that it is the correct length to get the sway bar level to the ground.
Thanks again for the info.
You guys are great.
191124x7
Jan 27, 2017 01:15 PM
savagebagz
Aug 7, 2016 09:08 PM
Jeff53
Jun 10, 2016 07:00 PM
2002exPSD
Jan 21, 2016 08:47 PM
Joe28443
Jun 12, 2010 11:23 PM
