hellwig sway bar
Old May 28, 2010 | 08:34 PM
Joe28443's Avatar
Joe28443
Joe28443
hellwig sway bar
I am in the market for a hellwig sway bar and checked www.jcwhitney.com I searched it and it came back as a sport tech body roll stabilizer by hellwig. It says this will fit my vehicle but it does not look quiet like the other hellwig sway bars on other sites. Its 148.39 and I thought about jumping on it if it is the same. Has anyone bought one from there that looks like that? thanks
Old May 28, 2010 | 09:56 PM
bwindell's Avatar
bwindell
I recently installed mine, and at the time JC Whitney did not have it to fit my EX. I ended up getting it from suspension connection and paid $209. If I remember correctly, this was the best price I could find three weeks ago.
Old May 28, 2010 | 10:06 PM
Joe28443's Avatar
Joe28443
Joe28443
it says on there it will be guaranteed to fit my 2001 ex. I dont know about all that. I will probably go where you did to be on the safe side
Old May 28, 2010 | 10:24 PM
bwindell's Avatar
bwindell
I just went to JC again to double check and nothing on the site for my rig. I did see the performance bar you mentioned, but again did not fit mine and it looks like a front bar to me from the pic on the site.
Old May 29, 2010 | 06:44 AM
Joe28443's Avatar
Joe28443
Joe28443
I had my vehice saved on the site. On the description it said it was for the rear. I would rather be safe and order from somewhere else
Old May 29, 2010 | 07:26 AM
ZBIGBIG19TH's Avatar
ZBIGBIG19TH
I'm on the same boat, can't see rear helwig for mine.
Old May 29, 2010 | 08:03 AM
Joe28443's Avatar
Joe28443
Joe28443
Maybe I need to investigate furthero
Old May 29, 2010 | 08:24 AM
Joe28443's Avatar
Joe28443
Joe28443
SPORT TECH BODY ROLL STABILIZERS
SKU Number: 2JA 494857 Manufacturer Number: 2801 Managed Saved Vehicles Remove All
My Vehicle:
2001 Ford Excursion
Change Vehicle
Product Options:Sport Tech Body Roll Stabilizer
Add to Cart
Quantity
Kit
Guaranteed to FitYour complete satisfaction is our #1 priority, so you can be confident the products listed below are GUARANTEED to fit your vehicle! But if for any reason an item just doesn't measure up, simply return it to us for a full refund or exchange within 90 days of receipt...no questions asked.
This product is guaranteed to fit or work with your 2001 Ford Excursion or your money back. No questions asked.
Sale Price: $148.39 $318.99 Kit Shipping:$3.99 Heavy Item SurchargeAvailability:Ships on 06/01/10 Special Offer:
Old May 29, 2010 | 08:45 AM
Joe28443's Avatar
Joe28443
Joe28443
the cheapest i have found is Performance Auto Parts and Accessories - StreetSideAuto . Suspensionconnection was cheaper but for the $40 shipping it put it at $249. streetsideauto offers free shipping but its $233. They are out of stock anyway I guess I will keep checking back
Old May 29, 2010 | 09:03 AM
jdadamsjr's Avatar
jdadamsjr
Try calling JCW and being nice ....
I did and they matched the lowest price I found and gave me free 3 day shipping and gave me a 10% discount
YRMV
Old May 29, 2010 | 09:12 AM
Joe28443's Avatar
Joe28443
Joe28443
I looked on the website at the pics and it did not pear to be the same. But I guess it will work if you have one on yours. I just purchased one at Helper Springs, Hellwig, Timbren, Firestone Air Bags, Leaf Springs, Sway Bars | SD Truck Springs @ $236 delivered. thats my luck.
Old May 29, 2010 | 10:50 AM
TXSailor's Avatar
TXSailor
Too late but.......................
There is an ASU discount for SDTruckSprings that will knock $20 off (ASU20).
I always do a search on Discount Codes before commiting to a purchase. There are just too many out there that go unused.
Old May 29, 2010 | 11:41 AM
Joe28443's Avatar
Joe28443
Joe28443
I tried several discount codes and none were valid. I even tried an ASU one and it was not valid. I don't think it was that one though
Old Jun 2, 2010 | 09:46 PM
FallstonYJ's Avatar
FallstonYJ
Don't mean to bud into this thread but I have a Hellwig sway bar for my 2003 that has been sitting in my garage for almost 2 months waiting to be installed. Any comments on how difficult/easy the install is and anything I need to look out for? Thanks, Tom
Old Jun 3, 2010 | 09:26 AM
TXSailor's Avatar
TXSailor
Installed mine last night. Took about 1 1/2 hours but I had to run around and get tools instead of planning a bit ahead. The only trouble I had was when I took the existing u-bolts off the lower Shock mounts, the shocks extended to theri full length (duh!!!) which made it difficult to get the new (much larger u-bolts) and sway bar plates lined up. I finally used my floor jack under the shock to get it pushed up enough that I could handle it by hand.
BTW - Hellwig's instructions are greatly lacking in clarity. Look at the wahsers carefully and read EVERYTHING that comes in the box. After I got everything bolted on but not tightened up, I found a separate enclosure that describes the washers and there intended use. Had to re-arrange my washers then. Also the parking brake holder on the Drivers side is wierd. I ended up just getting a separate bolt and nut from my junk box to remount.
Very happy with the results however and well worth the effort in 90 degree heat......
