Hellwig rear sway bar longer end links?
I just finished the modded b-codes with f350 dually factory blocks and my hellwig sway bar end links aren't remotely close to reaching. I have the old style bar. Checked on hellwigs website and they don't offer longer end links. Where can I get a set or do I have to make my own?
I modded the original Hellwig old style non-adjustable end links for my modded B code installation. Removed the rod portion and welded in a new longer and thicker threaded rod in it's place, used a tubular sleeve from top mount to a washer at the bottom to capture the lower bushings at the bar ends with two nuts under to lock in in position, the bar ends sit level now.
Can see a little of it here.
I would call Hellwig again, they supply adjustable end links with the bars currently.
Might have to go that route.
Since you have almost the same suspension setup as I do, what did you find to be the largest tires you could stuff on the ex. Cary said 35x12.50 on stock 18" 2004 Harley wheels are the biggest that will fit. I'd like to clear 37's. I have modded b-codes with f350 dually blocks and X-codes with 2" shackle drop. Looks kind of stupid now with 31" tires.
If I think of it I'll look at mine tomorrow in the daylight ( my truck is roughly 5 inches over stock). I had mine off this past summer and figured I'd rattle can it to clean it up. Took the sleeves off the threaded rod and cleaned everything and painted them. If you don't weld, it should be a really easy job for a fab shop to cut the threaded rod off, weld on longer rod and make a couple new sleeves.
One more thought if you don't weld. What if you made an angle bracket (piece of angle iron, for lack of a better description) to bolt to the bottom of the frame. Drill the appropriate sized hole for the end link bolt, and have the sway bar mount to the bracket . I've seen this done for the front bar with some lift kits, instead of having longer end links.
How in the world are you getting 6.5" inches of lift out of modded B codes and the F-350 blocks?
I run modded B codes with the F-350 blocks AND two sections of the thick factory traction bar and my EX has only 5" of additional ride height from that combination.
Read this thread https://www.ford-trucks.com/forums/1...easurents.html to see what others have done and what they measure out to, then take some measurements of yours to compare and figure exactly where yours is. Add your data to that thread also, the more info out there the better!
