Computer reset after battery disconnected?
Old Mar 18, 2006 | 07:48 AM
Tom.Lapham's Avatar
Tom.Lapham
My '91 f150 4.9L 5spd has a little miss when taking off easy. I've had the negative cable disconnected for a week while it was in my basement with the trans out waiting for clutch parts (got shipped the wrong part #*%##!!!).
My question is if it's possible that the sputtering may be due to the computer resetting, or would that even happen if only the negative cable was pulled?
Old Mar 18, 2006 | 08:37 AM
Bob Ayers's Avatar
Bob Ayers
The PCM will reset with the battery disconnected (negative or positive cable) that long. Has the check engine light come on?
Old Mar 18, 2006 | 04:54 PM
924x2150's Avatar
924x2150
Unfortunately the computer reset, and more bad news is that it shouldn't take too long to re-compensate.
Good news! You should have a clean slate to start with when pulling your diagnostic codes. THat is the only place to begin. See Fordfuelinjection.com for the procedure, the Haynes or chiltons has the procedure as well.
Ford electronics, emissions, and fuel systems will cause problems if you look at them the wrong way; It is a great system, but if just one or two sensors or actuators aren't working dead-on correctly you'll get hesitation or rough idle. Many idle problems are caused by build-up of oily carbon deposits, that clog things like your IAC, PCV, throttle body and butterfly plate, etc. etc.
We need codes!!!!!!!
Go to the store and get a can of SEAFOAM asap, a good intake cleaning may be needed. Do a search for SEAFOAM here, you'll find out how to use it, although the instructions on the can work too. I SEAFOAM my engine intake a few times per year.
Old Mar 19, 2006 | 12:30 PM
water 5's Avatar
water 5
the computer resetting should not make you truck miss it will run little rough first start up after siting. but check your ignition system wires cap & rotor for build up. and fuel filter if you are not gitting anny codes
Old Mar 19, 2006 | 12:35 PM
quicklook2's Avatar
quicklook2
check for loose or bad plug.
Ranger Bob
1983 - 2012 Ranger & B-Series
Jun 7, 2012 05:08 AM
nolanb
Jun 21, 2010 10:53 PM
SteelHorse08
2004 - 2008 F150
19
Mar 11, 2008 09:09 PM
ocean 9
Jul 5, 2006 12:37 PM
Webnut49
Apr 14, 2003 11:25 AM
