Roof Leak?
Old Mar 17, 2006 | 08:57 PM
mtcox's Avatar
mtcox
Roof Leak?
Has anyone had a problem with a mysterious roof leak at the left rear portion of the passenger compartment? I have a 2001 that leaks only occasionally. I didn't want to start tearing out the headliner before I had a rough idea of what needed to be done.
Old Mar 17, 2006 | 10:08 PM
amm888's Avatar
amm888
do you have a sunroof?
Old Mar 18, 2006 | 06:24 AM
mtcox's Avatar
mtcox
amm888,
No sunroof. It may be coming through the rear lift gate, but I'm not entirely sure. It only happens during really bad rains, too.
Old Mar 18, 2006 | 12:02 PM
amm888's Avatar
amm888
yeah rear lift-gate is the only other place i could think of then, unless you've got the rear windows that pop open (though i doubt that would cause a look from the roof).
checked all your seals around the lift-gate?
Old Mar 19, 2006 | 08:23 AM
mtcox's Avatar
mtcox
Amm888,
I'll look into the lift gate later this week. We haven't had rain in quite some time. Do the lift gates normally cause problems?
Old Mar 19, 2006 | 09:33 AM
fordsuvparts's Avatar
fordsuvparts
I used to have a 99 Navigator that had a leak in the rear and it was the quarter glass seal. I had to take it out and put a new ribbon seal on it. IT was about 10.00 for the the new seal, I used a 3/8 and rolled to make it thinner,it comes in a roll at a body shop supply store. It was a fairly big job to take out and re do. It was leaking on the top of the quarter glass. To find the leak, I took off the interior trim panels and got inside with a flashlight while someone sprayed it with a pressure washer. It was very obvoius where the leak was. Hope this helps
Kirby
Old Mar 19, 2006 | 03:18 PM
amm888's Avatar
amm888
mtcox, i really don't know if the lift gates are sources of common leak problems - my trucks have been nice and dry (we somehow make it through all this southern cali rain!). i was just suggesting some possibilities. hope you get 'er fixed,
al
Old Mar 24, 2006 | 02:17 PM
Chainsawz's Avatar
Chainsawz
I had the same problem with my 2001. At first, I thought it was the sunroof. After making many adjustments to the sunroof with no change, I tracked it to the roof rack. I had to remove the roof rack and re-seal.
Old Mar 24, 2006 | 08:23 PM
fordsuvparts
I forgot in my earleir post that I had a roof leak in a 98 navigator that i had fixed. It was a roll over. Turns out the shop did no tighten all the roof rack bolts all the way and water just dripped in in one of the holes. I took each one out and put a little squirt of silicone in each hole before i put the little torx bolts back in. No more leaks.
Old Apr 1, 2006 | 01:28 AM
99ExpHere's Avatar
99ExpHere
I have the same prob but its only if u use the rear window washer and then it starts to drip on the passanger roof liner whats causing this?
Old Apr 2, 2006 | 11:10 AM
triton54's Avatar
triton54
i've noticed after looking on mine that the rear washer nozzle just turn freely. when i turned it, it created a small opening but when put back in regular position. I myself have not had any leak troubles but maybe yours is cocked one way and maybe a simple turn could stop your leak. save you some money troubleshooting the problem maybe.
Power_strokeprinces
Dec 9, 2016 05:40 AM
Richwon4
Jun 16, 2016 09:11 PM
street rodder
Apr 1, 2016 10:56 PM
DET17
Aerostar
18
Jan 6, 2016 03:35 PM
Welder7018
Jul 25, 2015 08:30 PM
