Rear stabilizer shock
Old Mar 16, 2006 | 11:38 PM
explorerford1999's Avatar
explorerford1999
Exclamation Rear stabilizer shock
Anyone replace the rear stabilizer shock that is on the right side just in front of the rear differential? It's on my 99 explorer but can't find it in my repair manual.
Old Mar 17, 2006 | 09:42 AM
CobraXP's Avatar
CobraXP
I've never replaced mine. I know some that have, but they state they have not noticed a difference in their X - normal driving, pulling, etc.
Old Mar 17, 2006 | 09:45 AM
explorerford1999
Question
Thanks, I have had a problem when towing with my truck. It will start swaying from side to side. I had the front end replaced and new shocks installed. Helped a little but just thought that may help.
Old Mar 17, 2006 | 09:55 AM
CobraXP's Avatar
CobraXP
I would recommend getting different sway bars to help the swaying. Makes a WORLD of difference. Look at a company called Explorer Express and check on their X-Spec Sway Bars for front and rear. I run them with Energy bushings. Huge difference over stock. I was concerned over their price at first, but after instlaling them, I think it was one of the best mods I did to the suspension.
Also - make sure you have enough tongue weight on your trailer. If you have a counterbalance of weight towards the rear of the trailer, the trailer will swing.
Old Mar 21, 2006 | 11:18 AM
aquanaut20's Avatar
aquanaut20
Another reason folks get rear end sway is too light a tire (2ply) as is installed OEM, I recommend installing a LT tire (6ply) if you are doing any major towing.
Old Mar 21, 2006 | 02:18 PM
explorerford1999
Smile
I think I will try new tires. I have BF Goodrich Trail TA's. They are just the P235 series so I will check around for LT series tires. Thanks.
MoreBoostPlease
Mar 23, 2010 02:27 PM
mdwilli
Apr 21, 2009 10:25 PM
Biggziff
Jun 13, 2007 07:09 AM
jade97
Jul 23, 2005 12:02 AM
