Recommend shocks and steering stabilizers
Old Mar 22, 2010 | 01:21 PM
MoreBoostPlease's Avatar
MoreBoostPlease
I'd like to upgrade the shocks and steering stabilizers on my Ex, as well as do the VB spring swap. I'm curious what the most recommended shock is for the Ex - Bilstein HD, Ranchos, etc. How about a good dual steering stabilizer?
Old Mar 22, 2010 | 04:50 PM
kershman's Avatar
kershman
Seams to be most folks recommend the Rancho RS9000XLs. I just ordered 4 at Sears and with their free install, the total is $365 with tax.
Old Mar 22, 2010 | 06:09 PM
X-Hibition's Avatar
X-Hibition
I like my Icon dual stabilizer, a true push-pull arrangement. The price will scare you though.
Old Mar 22, 2010 | 06:34 PM
Stewart_H's Avatar
Stewart_H
I'm a Bilstein fan.
I have 'em on my Lightning, my Ex, and my 250.
Stewart
Old Mar 22, 2010 | 08:38 PM
wallz's Avatar
wallz
I also used the ranchos, and put them on before my vb spring swap and they were still ok length wise after the new springs.
With the heavier psd motor you might want to go with a heavier spring like the w or x code. More I guess depending on how much you want it to go up in the process. Most manufacurers do make a dual steering stabilizer, but on some of them you won't like the price. I went with the single rancho.
Old Mar 23, 2010 | 04:19 AM
CanadianSmokie's Avatar
CanadianSmokie
Biltstein HD's here... perfect damping for these heavy trucks.
The adjustability of the Ranchos looked appealing but I'm not the type to be out changing the settings on them.
Old Mar 23, 2010 | 04:56 AM
MoreBoostPlease
That's what I was thinking as well.
Old Mar 23, 2010 | 04:59 AM
MoreBoostPlease
Do you happen to know if the Bilstein's would still be long enough with the vb swap? Also, I'm expecting the vb's to give me about 1.5-2" in extra height.....not really looking to go any higher.
Old Mar 23, 2010 | 06:48 AM
Screamin6's Avatar
Screamin6
Let me know if you want a deal on Bilsteins. I am taking them off (wife doesn't like the ride) for RS9000XLs.
Old Mar 23, 2010 | 07:23 AM
CanadianSmokie
When you order the shocks, get the F250 fronts.... they have a longer travel as the F250 sits higher stock than the Ex did. You need to get the Excursion rears as they have a different mounting configuration than the trucks.
For the rears, you should be fine with 1-2" of lift but if you want to be sure, the rear shock mounts are only fastened to the axle tube with U-bolts... loosen them up, turn the mount to where you want and tighten down.
Old Mar 23, 2010 | 07:32 AM
Nosedive1's Avatar
Nosedive1
Originally Posted by Screamin6
Let me know if you want a deal on Bilsteins. I am taking them off (wife doesn't like the ride) for RS900XLs.
What doesn't your wife like about the ride with the Bilstein's. I am about to put some on our Excursion which is my wife's daily driver. Are the Bilstein's stiffer than stock?
Old Mar 23, 2010 | 07:47 AM
Screamin6's Avatar
Screamin6
They are very stiff IMO. Much more so than the minivan that's for sure (and a good thing). For towing they are great, but you can feel every bump in the road. I like a more Cadillac type of ride, but also want to make them stiff when towing.
Old Mar 23, 2010 | 07:49 AM
Nosedive1's Avatar
Nosedive1
Thanks for the info Screamin6. Looks like it'll be the Rancho 9000's for me too then.
Old Mar 23, 2010 | 11:07 AM
Johnny Langton's Avatar
Johnny Langton
I'm game..how long have they been on there?
JL
Old Mar 23, 2010 | 11:37 AM
Screamin6's Avatar
Screamin6
JL
Just about 1 year. We can PM if you are interested. I am in NE PA, if you are close we can meet up.
Thanks,
Steve
