Just got my superchips microtuner yesterday and installed 87 octane tune on my 97 F150 4.6 auto 180200miles. My check engine light came on after taking dad to work and got these codes.
P1000-Monitor checking not complete-More driving required
P1134-Bank1 Fuel ctrl switched rich (FAOSC)
P1154-Bank2 Fuel ctrl switched rich (FAOSC)
Please help the same codes came up this morning on my way to school. Turned around went home reinstalled stock program. At school installed 87 octane tune no check enggine light on way home. What do these codes mean????
The DTC code reader book from superchips lists the two codes. I went for a about 100mile drive no light at all, light came back on after I took my dad to work. I'm thinking the truck needs to be shut off for 7-8hrs. Could my K&N filter have anything to do with the codes being set? Or should I reinstall stock program and run the tank down and install one of the performance tunes? Pulled codes this morning and had two different codes.
P1133 Bank1 fuel control shifted lean
P1153 Bank2 fuel control shifted lean
Just sent an email to SperChips about the codes. One of the guys at work said it could possibly be that my upstream Ho2 sensors are the cause. I don't know if they have ever been replaced.
I put a Superchips 1714 (I think) on my 97 and it made the engine ping when set on either one of the performance tunes. I ran it for two weeks with several different gas grades then returned it and got all my money back after I showed the manager the fine print saying "30 day money back guarantee" So...if you are not happy return it soon.
