need some help 7.3 engine
Old May 22, 2012 | 09:35 PM
ampslw's Avatar
ampslw
ok i need some help
was driving home and all of a suddon no power didn't sound right check engine light came on and started to sputter this is the codes that came up got home read with AE and these asre the codes that it spit out
P1140 Water in fuel
p1316 Injector driver module codes detected
p1247 turbo bust pressure low
p0541 intake air heater circut low
tired to do key on engine off and it told me
p1294 injector high side open bank 2
cleared all codes and retested 2 codes came back p1316 ,p0541
tired to do cylinder contribution test would not retest due to two codes
P 1464 A/C demand out of self test range
P0541 Intake air heater circut low
Would not do KOER test either due to the same two codes
after clearing codes check engine light comes on as soon as it starts can not not clear code while engine is running
at an idle
exhuast back pressure 16.25
engine RPM 654.2
Injector control pressure - volts 0.80
volume fuel desired 14.2
injector ctrl pressure dc 8.20
injector ctrl pressure 486.48
manifold gauge pressure -0.04
manifold absolute pressure 13.6
mass fuel desired 11.88
at 2633 RPMS
exhuast back pressure 24.98
engine RPM 2633
Injector control pressure - volts 3.09
volume fuel desired 40.40
injector ctrl pressure dc 28.12
injector ctrl pressure 2394.3
manifold gauge pressure 2.75
manifold absolute pressure 16.50
mass fuel desired 35.88
does anyone have an idea at per what is going one the truck has absolutly no power doesn't sound right almost kind of like some cylinders are not firing when i did a buzz test i heard all injectors firer a few did not sound as loud as others
when you do a buzz test does it do all at once then one bye one ? I counted 9 buzzes
if anyone has any ides of what direction to point me in or if require some more information please ask
Old May 22, 2012 | 09:41 PM
Shake-N-Bake's Avatar
Shake-N-Bake
I suggest you pull the passenger side valve cover and plug the harness back in. Then see if it runs better and try to clear the codes.
Yes, there are 9 buzzes. The first buzz is all 8 injectors hard. Then 8 more buzzes, each with 1 injector hard and the remaining 7 injectors soft.
Edit: See post #6. Bank 2 is Drivers side, which is the valve cover harness to check instead of Passenger Side like I first suggested...(Oops)
Old May 22, 2012 | 09:45 PM
ampslw's Avatar
ampslw
question
why would automatically assum the passenger side ?
if i did the 50 cent mode would that had pervented this if it has come unpluged ?
Old May 22, 2012 | 10:41 PM
Shake-N-Bake
One of the codes said high side open on Bank 2 which is the passenger side.
Yes, the $0.50 mod will prevent the harnesses working loose.
Your symptoms indicate a loose harness under the valve cover as a prime suspect. It is free to check so that is why I was suggesting you look there first.
Hope this helps...
Old May 22, 2012 | 11:39 PM
Bonanza35's Avatar
Bonanza35
I agree. Open it up.
Chet
Old May 22, 2012 | 11:54 PM
Shake-N-Bake
Apologies...
My error. Bank 2 is the drivers side on these engines.
I was using AE to trouble shoot an O2 sensor issue on my LT1 and bank 2 on that engine is the right side. I knew I would get myself confused one of these days....
Old May 23, 2012 | 06:07 AM
Tugly's Avatar
Tugly
Put your head between the speakers to hear this in stereo. This is how the buzz test is supposed to sound.
Stinky Injectors.MP4 - YouTube
Old May 23, 2012 | 06:29 AM
landmobile's Avatar
landmobile
Thanks Tugly, that helped answer one of the questions in my injector testing thread.
Chris
Old May 26, 2012 | 12:41 PM
ampslw's Avatar
ampslw
finaly got some time
This is going to be fun ........I had to move the truck to day and it ran fine for about 5 min. Then back to what I said was going on
Old May 26, 2012 | 04:53 PM
ampslw's Avatar
ampslw
hi
Look like it was all most unpluged is there anything I should do since I have it open.
Old May 26, 2012 | 05:14 PM
bcaughhorn's Avatar
bcaughhorn
50 cent mod. and retorque everything
Old May 26, 2012 | 05:16 PM
ampslw's Avatar
ampslw
Retorque everything. Spec ?
Old May 31, 2012 | 10:25 AM
ampslw's Avatar
ampslw
Just wanted to say thank you for the help. Fte crew was right agene
Old May 31, 2012 | 12:40 PM
Brother Les's Avatar
Brother Les
Did you get the specs to re torque your under the valve cover stuff? Rocker arms, etc.
Old May 31, 2012 | 12:46 PM
ampslw's Avatar
ampslw
No never got the specs. But will do next time I'm working on it need to do the up pipes at the end of june
