Flashing Overdrive light
Old Mar 15, 2006 | 08:59 AM
jeem's Avatar
jeem
Yesterday I noticed that my overdrive light on my shifting lever was flashing and my truck was shifting hard and the overdrive was off.
I pulled over and turned the truck off and the problem cleared.
It happened twice. Any ideas?
1999 F250 7.3 PSD
Old Mar 15, 2006 | 10:25 AM
blhfla's Avatar
blhfla
Check the bottom half of this thread:
https://www.ford-trucks.com/forums/s...&highlight=VSS
When my VSS was bad I had ABS lit, erratic speedo below 50 MPH, flashing OD, erratic auto trans. at slow speeds and cruise control malfunction. $21.67 and a new VSS later they all went away.
Old Mar 15, 2006 | 10:55 AM
empiretc's Avatar
empiretc
Hopefully its the vss. You might still need to get the codes pulled.
Old Mar 15, 2006 | 12:32 PM
clintbonnie's Avatar
clintbonnie
I got my new VSS.. or Napa calls them ABS sensor.. from Napa they are less than $12.. works great.. located on top of your rear-end..
Old Mar 15, 2006 | 01:09 PM
IABill's Avatar
IABill
Wink
Jeem, Next time it happens get it to a shop and have it scanned it's setting a code and going to failsafe. If it stops after re-start then happens again after driving the puter is pickin up the problem again. even if the od lockout lite is not currently on a code should be stored to tell you what the problem is or at least where to look.... hope its only a sensor....Good luck.....Bill.
Old Mar 15, 2006 | 05:26 PM
LUMBERMAN's Avatar
LUMBERMAN
That happened to me , it was the speed sensor,thats not saying thats what your problem is ,just process of elimination.
Old Mar 15, 2006 | 07:49 PM
jeem's Avatar
jeem
Thanks for all of the input
Thanks, people!!!!!!! Could some post a picture for where the VSS is? I am not very good when it comes to truck repairs, but if I had a picture I might try and tackle it myself.
Old Mar 15, 2006 | 07:55 PM
bad ass diesel's Avatar
bad ass diesel
i am having the same problem with o/d on or off seemes to be shifting alittle hard. no erratic speedo though i have put it in neutral at a light and the rpm's are erratic on occassion. hopefully going to have it scanned tomorrow, ill keep u posted
Old Mar 15, 2006 | 08:01 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
here jeem-
Old Mar 15, 2006 | 09:01 PM
jeem's Avatar
jeem
Thanks alot stroke
Old Mar 16, 2006 | 05:32 PM
dartol's Avatar
dartol
My 2002 just started doing the same thing today. Ugh. So I am in it with ya. On the other thread referenced above, someone suggested cleaning the contacts on the VSS. I think I will try that first.
Darren
Old Mar 17, 2006 | 05:39 PM
bad ass diesel
I just had mine scanned..... is is the MLP sensor it is not telling the comp. what gear I have selected. It was picking up park, reverse, and drive 1. so i am going to check the electrical contacts, try it and if that does not work buy a new sensor
Old Jun 27, 2006 | 07:31 PM
EBrown's Avatar
EBrown
I wish you guys would stop with the acronyms
MLP sensor?
Old Jun 27, 2006 | 08:45 PM
dartol's Avatar
dartol
My problem ended up being a bad servo pack in the transmission... $500 fix. Ouch.
Darren
Old Jun 27, 2006 | 08:52 PM
kennedyford's Avatar
kennedyford
Gentlemen, when the od flashes and it shifts hard it is going into protection mode. We are currently working on mine in the tranny shop. First process of elemination was a servo, now were trying to track down an electrical issue. The fact that it is flashing is telling you that it is preventing further damage. Let it shift hard until you can get into the shop. Troy
campbell99
Oct 28, 2023 08:42 AM
jbs08
Oct 24, 2011 09:39 PM
risky97psd
58
Sep 13, 2008 06:37 PM
trix75
Apr 3, 2008 05:57 PM
russwa
1978 - 1996 Big Bronco
Jul 19, 2001 08:17 PM
