3" Downpipe
Old Mar 19, 2006 | 02:43 PM
mjwhip2's Avatar
mjwhip2
mine is sitting on a shelf in the garage.
Old Mar 19, 2006 | 05:26 PM
1996pwrstrk's Avatar
1996pwrstrk
I don't even let the cat in the shop, its laying outside .
Old Mar 19, 2006 | 05:52 PM
Jerrybo66's Avatar
Jerrybo66
I talked to a guy that knows a guy that said he would kill my Cat for $75.00. He said he would remove it from it's home, gut it, put in a sleeve and return the carcass. It sounded like a deal so I contracted to have the job done. Does the price sound about right for the amount of work have the Cat wacked? Or should I forgetaboutit ?...
Old Mar 19, 2006 | 06:48 PM
mjwhip2's Avatar
mjwhip2
Originally Posted by Steve Baz(Baz's pages)
Gutting The Cat
Cat Delete Pipe -- Ford part number F4TZ-5A212-V
Best way to remove the cat is to loosen the clams front and rear. With a marker mark the front and align the mark at the very bottom to help you get it back on in the right direction and bottom facing straight down. NOTICE THE LITTLE TIT AND NOTCH AT THE BACK OF THE CONVERTER, THAT MUST BE LINED UP TO RE-INSTALL. Unhinge both muffler hangers behind (2) of them go to the drivers side of the truck and pull the cat in that direction and with a dead blow hammer or a heavy hammer OR with a piece of 2 x 4 hit the cat forward until it releases. Then wiggle the front section loose.
Now is the fun part. With a steel breaker bar or a pipe or anything that is longer than the length of the cat start beating the honey comb up and keep dumping it out of the side your hitting. do this until it is all out. Hint beat the crap out of it is not as simple as it seems. Make sure it is all clear before removing because you do not want any rattles.
Installing the cat back by banging the cat fully into the front using the mark to align the cat right and the arrow forward. Hint: Make sure the cat it seated all the way forward before re-claming. Then make sure you align the back to the tit and notch before you start banging the back in place. Make sure the tit is all the way seated before clamping and set the hangers back before tightening the clamp. Finish tightening and then go back and tighten again because it must be very tight. Check the exhaust hangers and make sure they are on properly. Your done...... Great job you just gutted the cat.
Or you could just pay someone, messy as hell. Have fun.
Mtnhermit
Apr 30, 2016 12:57 AM
Dutch123
1978 - 1996 Big Bronco
Jul 9, 2010 04:48 PM
Eric_F250
24
Mar 24, 2009 08:48 PM
Greywolf
Tennessee Chapter
Aug 25, 2006 06:29 PM
