edelbrock cams?
Old Mar 15, 2006 | 06:00 PM
busted knuckle's Avatar
busted knuckle
ok i know rogers motor will make some serious power. but i dont have that kind of money right now. so can i purchase the cam and lifters and order at the same time the valvesprings and get all the same componets minus timing set? then sub in a cloyes or summitt or somrthing? basically what im askin is will i still get all the retainers and locks and like parts by ordering just the cam and springs?
Old Mar 15, 2006 | 06:06 PM
busted knuckle
btw what kind of idle will the 265deh provide?
what about the power range of this cam does it prove useable?
thanks alot its good to hear from people who have already used/researched theese products.
Old Mar 15, 2006 | 06:44 PM
danlee's Avatar
danlee
Call Summit Racing, or Jegs about getting the K kit, with a substitution for the timing set.
Here is the description for the 265DEH.
Very strong mid-range performance. Everyday usage for stock exhaust. Noticeable idle. 1500-5750 RPM.
Old Mar 15, 2006 | 08:15 PM
roushracing617's Avatar
roushracing617
Just a heads up. I ordered the Comp Cams XE 262 k-kit, and it came with the Magnum timing set, which is a true double roller set-up. Maybe the non XE k-kits come with a standard set, but mine did not. You may want to call Summit and inquire. Let us know what you find out.
Old Mar 15, 2006 | 09:19 PM
busted knuckle
thanks for the replies. would i get the retainers and stuff. ill call summit tomorrow and see about timing set and springs.
Old Mar 15, 2006 | 10:30 PM
busted knuckle
Talking new info on comp cams (prev. edlelbrock cams)
just left summits web site and the k32-207-3 kit is 400ish bucks and comes with a standard timing set(non roller).
if you order the valve spring kit you do get the locks and retainers as well as you would in the k kit.
TO THE POINT
sorry about caps just seperating info.
the valve spring kit(126$)+ dual roller timing set(49$)+ cam and lifter kit (179$)
= grand total 354$ i think thats what it was if you dont believe me i gave you the numbers math isnt my thing at 11:30pm.
so we get better parts for less dream come true.
Old Mar 15, 2006 | 10:47 PM
Torque1st's Avatar
Torque1st
Posting Legend
Threads merged.
Old Mar 15, 2006 | 10:52 PM
53fatfndr's Avatar
53fatfndr
Do you have the part number for the valve spring kit?
Old Mar 16, 2006 | 12:44 AM
busted knuckle
not on hand ill look it up tommorow if u want. it is on summits website.
Old Mar 16, 2006 | 02:03 PM
53fatfndr's Avatar
53fatfndr
I looked on their site but I wasn't turning up anything. Let me know if you find it
Old Mar 16, 2006 | 09:56 PM
busted knuckle
The part number is CCA-982-KIT the price is $126.39 on Summit.
Old Mar 16, 2006 | 10:09 PM
53fatfndr's Avatar
53fatfndr
Thanks
Old Mar 17, 2006 | 01:21 PM
  #28
busted knuckle
no prob sorry it took so long. i think i will just buy pieces seperate to get the parts i want and save a dollar along the way. just me tho. if anyone uses these parts b4 me please let me know. ill post my results when i get around to it.
79FordBlake
Sep 9, 2008 02:04 PM
fozzy
Aug 2, 2008 09:44 PM
ladiabla74
Dec 23, 2007 03:51 AM
7702fordboy
Aug 28, 2006 01:49 AM
CoachRobb
Oct 12, 2004 08:21 PM
