Sponsored by: Kumho
Which lift kit?
Old Mar 13, 2006 | 10:52 PM
fordtruckman78's Avatar
fordtruckman78
Which lift kit?
Im in high school and have a 1978 f150 custom 4x4, and would go mudding sometimes and i was wonder which kind of 4" lift is better, one with rear blocks or one with a rear "add a leaf" rear springs. All info and opinions are helpful.
thanks,
steve
Old Mar 14, 2006 | 12:18 AM
ivanribic's Avatar
ivanribic
Blocks are a bad idea. Ideally a replacement rear lift spring is the way to go but if that's out of the budget I'd opt for the add-a-leafs out back. 4" blocks increase axle wrap and can end up destroying the springs, axles and u-joints in a short time.
Old Mar 14, 2006 | 05:38 PM
1975Ford's Avatar
1975Ford
check out the one at Jeff Bronco's Graveyard, Rancho, Superlift.
Ivanribic is right, go with the leaf spring setup, your truck will be ready for some real fourwheeling with out the axle wrap.
Old Mar 15, 2006 | 10:04 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Skyjacker. Period.
Old Mar 15, 2006 | 10:23 PM
fordtruckman78
Has any one used rough country? and are they any good and keep in mind im in high school so ya rough country is cheap but its around what i can afford.
Thanks,
steve
Old Mar 16, 2006 | 08:11 AM
1975Ford's Avatar
1975Ford
Their product line has improved. I run ranchos and superlift.
davefrommd
Mar 9, 2017 05:44 PM
BIGTRUCKBIGRV
6.7L Power Stroke Diesel
Jun 29, 2015 11:41 AM
sjustice64
Jul 31, 2009 01:25 PM
xcnick38
2004 - 2008 F150
Jan 15, 2009 08:53 PM
PowerstrokeJunkie
Mar 12, 2006 05:55 PM
