highboy manual to automatic
Old Mar 13, 2006 | 08:39 PM
oldblue31's Avatar
oldblue31
If I convert my 4 speed highboy to automatic what will be involved?
Old Mar 13, 2006 | 08:54 PM
ivanribic's Avatar
ivanribic
Remove 4 speed, install automatic. Viola!
Seriously though, there's nothing to it. Going the other way around is a little tougher. You'll need to find an auto (C6 I assume) with a bellhousing that fits your engine. Then a flex plate and torque converter. Because you're using it in a high-boy you can use a 2wd tranny. You'll probably need to fab a mounting point for your t-case shift lever (this can be done off the cross member). You'll need a shifter for it, easiest way is to get a floor shifter like Lokar or a B&M Megashifter.
Old Mar 14, 2006 | 12:02 AM
fordraceboy's Avatar
fordraceboy
you'll also have to shorten the center driveshaft by a few inches... you'll also have to slide the tranny cross member back a bit- just slot the holes and you'll be okay. when i swapped mine from auto to 4 speed i also had to be sure and use the C6 tranny mount pad on the 4 speed cuz things just wouldn't line up perfect if i didn't.. i checked around and they do have a diferent part number for each of them so someting is a bit different- even though they mount to the tranny identically. good luck!!!
CFarrell
Apr 25, 2017 02:37 AM
tbruz
Oct 28, 2015 03:20 PM
workingdog
Jun 15, 2006 04:28 PM
jowilker
Nov 18, 2002 08:11 PM
Highboy70
Oct 19, 2002 12:10 AM
