How do i identify the rear diff gear ratio?
Old Mar 13, 2006 | 11:59 AM
385seriesHemi's Avatar
385seriesHemi
What do i have to look for to determine the gear ratio on the gears for any rear end? does it say on the ring/ pinion or what?
Old Mar 13, 2006 | 01:05 PM
pitrow's Avatar
pitrow
Well the sure fire way, if you have the rear cover off is to count the teeth on the ring gear and the pinion gear. Then devide the ring gear tooth count by the pinion gear tooth count and that will give you the ratio. Not all (actually not many at all) are stamped with numbers. Sometimes you'll find a tag on the diff cover that says the gear ratio, but they often get lost or are simply not there, or may even be incorrect. Counting the teeth is about the only way to know for sure.
Old Mar 13, 2006 | 01:38 PM
76 F-150 390FE's Avatar
76 F-150 390FE
you could also chock the front end and jack up 1 rear tire, put the tranny in neutral and spin the tire 2 times and count how many times the driveshaft turns.
Old Mar 13, 2006 | 01:47 PM
bryyce62's Avatar
bryyce62
Depending on the auto, it'll be in the VIN also. Just have to decode it.
gw
Old Mar 13, 2006 | 01:56 PM
Mil1ion's Avatar
Mil1ion
Pitrow gave the ONLY verifiable way to determine the exact ratio.
Rear ends get changed,tags get removed and one there may still be wrong, and doors get replaced.
Count the teeth and do the math
Old Mar 13, 2006 | 02:00 PM
RangerPilot's Avatar
RangerPilot
If you don't want to break into the diff for the "right" way, check the VIN, tag on the door, and look for a tag on the diff. They probably will all line up and be correct with each other, then spin the tires and look to see if it looks like it matches the number everything else suggested.
Though Pit and Mil1ion are right, that's the only way to REALLY do it.
OR, you can get your tire diameter, tranny ratios, and calculate it using one of those online calculators.
Old Mar 13, 2006 | 02:07 PM
385seriesHemi
Alright, thanks ya'll for informing me on this matter.
Old Mar 13, 2006 | 09:37 PM
Torque1st's Avatar
Torque1st
Posting Legend
This post contains a very accurate way of determining the ratio without counting teeth. It is from the FAQ thread in the 73-9 forum:
https://www.ford-trucks.com/forums/s...8&postcount=20
Old Mar 14, 2006 | 02:25 AM
aurgathor's Avatar
aurgathor
It's a waste of effort (and possible oil) to count the teeth -- it's possible to determine the axle ratio accurately by spinning the tire(s).
