tires leaning
Old Mar 13, 2006 | 07:48 AM
lgower's Avatar
lgower
tires leaning
81 f100 6cylindr. all new bushing and sterring components, go forward and tires tilt out. go in reverse and tires tilt in, any suggestions, oh yeah, king pin front end, thanks alot, lee
Old Mar 13, 2006 | 09:26 AM
Kalashtar's Avatar
Kalashtar
It sounds like weak springs.
Old Mar 13, 2006 | 09:33 AM
lgower's Avatar
lgower
wheels
why would it change with direction, if they were weak , wouldnt they lean in all the time
Old Mar 13, 2006 | 12:52 PM
RyanMiller's Avatar
RyanMiller
when you go forward the weight shifts and the front end lifts and in reverse the front end digs down?
that or your king pins are so worn that there is enough slop to let the camber change..
jack it up and wiggle the tire, if its solid, then its the springs.
Old Mar 13, 2006 | 01:02 PM
lgower's Avatar
lgower
tires
why does it tilt out just sitting
Old Mar 13, 2006 | 06:23 PM
Neb86's Avatar
Neb86
Your kingpins are worn, badly from the sounds of it. If the last direction your were traveling in was forward, then they would tilt out. The opposite would be true if you backed it up and parked.
After you fix the kingpins, get your toe-in readjusted. It will probably be wrong after the repair.
Let us know how you do!
EDIT: Did you adjust the toe-in after replacing steering components?
Old Mar 14, 2006 | 02:12 AM
the86beast's Avatar
the86beast
my 86 f150 does the same thing and everything in the front of my truck is tight.i even had my buddies down at my shop align it for me.i dont know if this is true or not but from what ive heard from them this is normal on the older ford trucks.these guys have been in auto repair for 30 plus years.so i kinda trust what they say.
Old Mar 14, 2006 | 03:45 AM
srercrcr's Avatar
srercrcr
How the tires wear will be the ultimate judge.
Old Mar 16, 2006 | 09:24 AM
Kalashtar's Avatar
Kalashtar
Not allways. when you drive forward, the weight shifts and the front raises a bit, tires tilt out. When you back up it pushes the front down, tires tilt in. weak springs amplify this and make it very noticable at the tires.
Old Mar 16, 2006 | 10:00 AM
lgower's Avatar
lgower
pins
seems as if I feel the front end wobbleing when i turn really sharp
Old Mar 17, 2006 | 02:58 PM
MRStace84's Avatar
MRStace84
After checking everything else mentioned, take a look at your shocks.
Old Mar 18, 2006 | 12:34 AM
Piffery1's Avatar
Piffery1
Bad radius arm bushings will cause that problem. Check for loosness with vehicle frame supported on jackstand and wheels about 1" clear above ground. Also check pivot bushings.
Old Mar 18, 2006 | 06:09 AM
lgower's Avatar
lgower
tires
read previous, all new bushings
arrowheadfred
Aug 29, 2010 08:03 AM
DJOHNSTON78
Sep 29, 2008 10:34 PM
imlowr2
Nov 8, 2005 08:41 AM
Dads79
Aug 5, 2005 09:22 AM
PaulB
1997 - 2003 F150
Aug 12, 1999 04:24 PM
