computer program HEELLP!
Old Mar 9, 2006 | 09:31 PM
rhw's Avatar
rhw
My friend from work burned me a copy of a computer program and I can't make it auto run or setup. He included some thing called "Daemon Tools" and I thought that was to open the files with but I can't figure it out. The Daemon tools installed fine and left me with yet another tool bar but I still can't run the program. One file says it is a "bin file" and the other says it is a "cue file". The bin file is 691 mb and is a read only. the cue file is 74 bytes and is also a read only. I have tried right clicking and opening them with every progam option thats listed . Any ideas? Thank in advance!
Old Mar 9, 2006 | 09:38 PM
go_racing84's Avatar
go_racing84
That's a disc image. If you have a burner program like Nero or something, you can open and burn it with that.
Old Mar 9, 2006 | 09:48 PM
rhw's Avatar
rhw
um... this is one of the many times that I tend to find myself so lacking in a knowledge base that I don't even know the question to ask! 1)What's a disc image 2) can I down load a program like Nero for free off of "downloads.com" or someplace? 3) if I just want to run it on my computer do I still need to burn it to some where? - Sorry-just a little "blue collor" for my own good!
Old Mar 9, 2006 | 11:22 PM
Mil1ion's Avatar
Mil1ion
What's the name of the program ?
The disc image could be an icon or a logo.
Old Mar 9, 2006 | 11:43 PM
rhw's Avatar
rhw
tda-aa05 it should be an auto cad type program
Old Mar 10, 2006 | 08:10 AM
fordboy_52's Avatar
fordboy_52
if you have a virtual drive like alcohol or clone cd u could mount the image and run it just like haveing a cd in the drive
Matt
Old Mar 10, 2006 | 08:11 AM
mistakenID's Avatar
mistakenID
Try just exploring the cd and look for an ***** file. Your friend most likely just burned the program it's self without any auto run file on the cd. Whatever the program is named should be on the cd as XXXXX*****.
To explore the cd, insert into your cd player. Open my computer, right click on your cd player and choose explore.
Old Mar 10, 2006 | 08:29 AM
ag-ford-4x4's Avatar
ag-ford-4x4
A disc image is an exact replica of the original, except in a compact, single file. It is designed to be burned to a CD with burning software. So, when you burn it, the software takes that image, opens it up, decompresses it, and puts it on the cd exactly as it came off the original, with the cd name and all. The program he gave you is probably used to mount that file and use it just like mentioned above.
Old Mar 10, 2006 | 11:21 AM
NASA_Hokie's Avatar
NASA_Hokie
Daemon Tools allows you to mount a disc image. It basically gives you a virtual cd-rom drive.
Old Mar 10, 2006 | 04:32 PM
twin66's Avatar
twin66
deamon tools icon should be down by the clock in task bar, mine is red, and has a red bolt of lightning down the middle. Right click the icon, go to Virtual CD/DVD Rom, Then device 0 or 1, then click mount image, and find the bin image off the the CD. it should load, then go into "my computer" and beside your normal CD drive icon, there will be another, with the "cd" loaded, just click on it, hit autorun, or go into the disc and find the setup file.
Old Mar 10, 2006 | 11:18 PM
rhw's Avatar
rhw
Hey! Thanks for all your help! I some how stumbled through the set up process laSt night about 11:00. couldn't have done it without all the support from you guys at FTE!!
ford2go
Jul 5, 2008 09:55 PM
bf250
Sep 17, 2006 08:35 AM
I6power
Jun 6, 2006 03:27 PM
unclehan
Jul 13, 2005 06:10 PM
