Sponsored by: Auxito
2003 SCrew headlights
Old Mar 9, 2006 | 07:08 AM
dmsman's Avatar
dmsman
I have a 2003 SCrew and my headlights are only on when I turn them on with the switch. I have a friend who also has a 2003 SCrew but 4x4 and he is unable to turn off lights when truck is turned on. He has taken it to two dealerships and no one can figure it out yet.
I'm sure someone on here will have ideas.
Thanks
James
Old Mar 9, 2006 | 08:53 AM
BillyBob69's Avatar
BillyBob69
Does he maybe have the daytime running lights option and you don't?
Old Mar 9, 2006 | 09:26 AM
dmsman's Avatar
dmsman
Thats what I was thinking but shouldn't there be a way to disable the running lights? Its just strange the dealerships don't know why its happening.
Thanks
Old Mar 10, 2006 | 12:12 AM
hood's Avatar
hood
Copied from another forum:
I want to Disable DRL on my Truck...
This is actually very easy. You need to find the resistor (See Location is Everything below) and disconnect it. It's that easy. And Yes... your low beam and high beams will still work with the resistor unplugged.
http://www.users.voicenet.com/~storm/drl/
http://www.users.voicenet.com/~storm...L-Resistor.htm
http://www.geocities.com/skyjet1/DRL.html
I added DRL's to my 02 F150. Two parts are needed that are omitted from U.S. purchased trucks. The resistor that is under the driver's fender area and the relay loopback plug that is located under passenger dash. Unplugging the resistor is all that is required to disable the daytime running lights. Good luck.
hwyhogg
May 24, 2012 08:48 PM
James Williams
1983 - 2012 Ranger & B-Series
Sep 1, 2010 07:03 AM
TheRon
Bronco II
Feb 28, 2009 11:43 AM
divejdt
Aftermarket Products
Aug 12, 2007 11:03 AM
FordF150_1996
Apr 2, 2005 03:12 PM
