Bronco II Ford Bronco II
Bronco busted...
Old Mar 13, 2006 | 08:14 PM
fordxfour87's Avatar
fordxfour87
but what i dont get is how the connecting rods are lubricated. isnt it lubricated by the surrounding oil around the bearings? i dont see how a constant pressure stream can be directly sent to the bearings. Is this done through a hole channled through th crank that sends presureized oil to the bearings? That would affect oil going to the top end?
Old Mar 14, 2006 | 12:32 PM
kernel-panic's Avatar
kernel-panic
I'm guessing that my rod bearings are pretty well-worn, then. I flushed my engine over the weekend and I still have valvetrain noise while the engine is running, but not so much the "dry start-up" noise. I'm currently running 20W-50... so I am guessing my next step is to drop the oil pan and double-check the oil pump pickup screen. If that checks out, I guess I'll end up having to do a mild rebuild... however, on another note, I do believe my front and rear main seals are leaking somewhat, so I may put a new pan gasket and front and rear seals and see.... All I know is the darn thing won't completely die LOL *shrug*
Old Mar 14, 2006 | 01:45 PM
fordxfour87
Yeh, dont worry about dry start up sound, i lloked in the manaul about it and it says thats complelety fine as long as it gos away within 3 seconds. Though my engine was messed up. glad its not, hope you have good luck finding out whats wrong
Old Mar 19, 2006 | 08:31 PM
stuffman2003's Avatar
stuffman2003
move to iowa you dont have that problem.lol sounds like a good idea to me thoguh.
BuffmanLT1
1983 - 2012 Ranger & B-Series
32
Sep 10, 2007 07:03 PM
RangerPilot
15
Sep 11, 2006 05:31 PM
JBronco
1978 - 1996 Big Bronco
Aug 23, 2003 09:55 PM
The Groovy One
Mar 28, 2003 01:33 PM
TallPaul
Exhaust Systems
Dec 25, 2001 04:01 PM
