MAF cleaning
Old Feb 4, 2007 | 01:00 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Originally Posted by rsylvstr
yes, bolted in with four bolts.
Actually, it's usually TWO screws, with anti-tamper Torx heads - the type with the pin in the center.
Old Feb 4, 2007 | 03:15 PM
rsylvstr's Avatar
rsylvstr
actually, it's four bolts that hold it into the MAF assembly itself....the two screws are what holds the MAF together and don't need to be taken off...
at least not on the 5.4 that i have and have taken apart to clean already.
Old Feb 4, 2007 | 03:52 PM
krewat's Avatar
krewat
I think we're talking about two different things.
The MAF sensor as a complete unit, and the sensor itself. To remove the sensor itself, there's two anti-tamper Torx screws hold it to the body, and CAREFULLY remove the sensor (and filaments) from the body. There's paint on the screws, so if it's tampered with, it's obvious - might void the warranty on the MAF - if you're still under warranty.
Maybe you're talking about the entire body? As in, remove the hoses from each side, and to remove the ENTIRE MAF assembly is FOUR bolts?
I wish I had pictures...
Old Feb 4, 2007 | 05:18 PM
rsylvstr's Avatar
rsylvstr
I think you're right.
I think we're both right LOL.
I know the paint and screws you are talking about....but i was able to disasseble mine and still spray her down without taking the two torx screws off...i think i cleaned it
Old Feb 25, 2007 | 01:11 PM
Fifty4F100's Avatar
Fifty4F100
We are getting a "Service Engine Soon" light on our 5.4 Excursion. I don't remember the codes, but our local Autozone told us that both sides of the engine are running lean. The 3 fixes they gave us were 1.) the fuel filter (just changed last summer), 2.) the O2 sensors (I have trouble believing that both went out at the same time) and 3.) the MAF sensor. Would cleaning the MAF sensor clear this problem? We replaced it as well last year when we replaced the fuel filter as we were trying to get rid of a miss that did not give any trouble lights. That problem was fixed by replacing 2 boots on the COP.
Old Feb 25, 2007 | 04:39 PM
rsylvstr's Avatar
rsylvstr
i would definitely try cleaning the MAF sensor and try a bottle of Techron concentrate or regane in the tank.
NovaNewfie
Modular V10 (6.8l)
Nov 8, 2013 09:02 AM
joe blow
Jun 4, 2013 12:36 AM
xc4jokestomper
26
Jul 28, 2010 08:58 PM
christaylor
1997 - 2003 F150
Jul 16, 2005 07:32 AM
sd1
Dec 23, 2003 03:48 AM
