egr
Old Mar 8, 2006 | 08:08 AM
shamrock442's Avatar
shamrock442
egr
I unpluged the egr on my 06 f350 and the check engine light came on which i knew would happen so i plugged in my scmt and tried to clear the codes to get the check engine light to turn off but was unable to get the light to turn off. Any suggestions.
Old Mar 8, 2006 | 08:50 AM
kw5413's Avatar
kw5413
Call the programmer boys. While I am not up on how to do it, I thought you could leave the EGR valve plugged in but, disable it thru the programmer.
Good luck.
Old Mar 8, 2006 | 11:34 AM
shamrock442
called superchips they said the check engine light will always stay on because afteryou clear the dtc code the next time you start it it will come back on.
Old Mar 8, 2006 | 08:49 PM
chadjones99's Avatar
chadjones99
no code here
i unpluged my egr on my 03 and i do not have a check engine light come on?
wounder why, i thought i would also
i also had it in to the dealer for other work and they flashed and checked codes and did not say anything to me
Old Mar 8, 2006 | 10:07 PM
Powerstroke_wannabe's Avatar
Powerstroke_wannabe
The 06 model now has 50 state emissions. This means the CEL comes on when you unplug the EGR. Prior to 06, I believe only the CA trucks would turn on the CEL with the EGR unplugged. Gotta love the EPA..... NOT!!!!!
Old Mar 8, 2006 | 10:08 PM
kw5413's Avatar
kw5413
'03 / '04 engine builds (non-California emissions) are OK. Took '05 / '06 to catch up.
Old Mar 10, 2006 | 02:51 PM
Diesel Man's Avatar
Diesel Man
If you leave it unplugged will it cause any long term problems for the engine? I unplugged my 05 and it ran much better. The cel light is on but I can live with that.
Old Mar 10, 2006 | 03:02 PM
DeesO's Avatar
DeesO
Here is something that I posted before
I was told by my ford tech after talking to him about the EGR putting the black smoke from my SCMT back into my intake that, with the new flashes, it’s not worth it to mess with the EGR. According to him, the early flashes DID hold it open too often, and would often get stuck, so it was worth messing with. However, the new EGR valves have a redesigned mating surface, to prevent sticking. The new flash also “exercises” the valve, meaning that if the valve is running half open, instead of just closing it, occasionally the computer will open it all the way and slam it shut, keeping it from sticking. The tech also said that with the newer flashes, the EGR only opens up in steady state modes (extended idle, cruise conditions), and that it closes when the accelerator is moved any significant distance.
This is what I was told by my tech, and I have enough confidence in his ability to believe him, so take this for what its worth.
DeesO
Old Mar 10, 2006 | 03:17 PM
Diesel Man's Avatar
Diesel Man
Yes but if you LEAVE it unplugged will it hurt anything?
Old Mar 10, 2006 | 09:12 PM
spycatcher70's Avatar
spycatcher70
I plugged mine back in. It ran much slower, tranny felt jerky.. the boost went from about 25 (was running about 28ish before the ford re-flash) to about 21.
Old Mar 10, 2006 | 09:17 PM
chadjones99
Exclamation 21
at 21 pounds you should pull over and shoot the truck right in the turbo !!!!!!!!!!!!!!!!!!!!!!!!
Old Mar 10, 2006 | 09:20 PM
spycatcher70
yeah I hear ya. it's at the shop now for a "sudden loss of power"....I begged and pleaded with the shop dude to undue the reflash...
lottery_loser
Feb 26, 2014 09:11 AM
BoardriderX
1983 - 2012 Ranger & B-Series
Oct 1, 2013 07:38 PM
supramafia
Aug 24, 2010 01:40 PM
clevelandjim
Feb 21, 2005 08:04 AM
MetallicaFan39
Jun 1, 2004 08:47 PM
