year of motor
year of motor
A friend of mine has a 1970 f100 with a 360 bored 30 over and we are trying to find out what year the motor is, biggest problem we can't tell what the right size push rod to put in it. Second ? is when you start the truck in the morning oil pressure sits at 40 untill you start driving down the road and it drops to 25 and stay at 25 is that a problem.
any help would be appreiciated
thanks
Scott
LowCoutry Swampers
thanks
Scott
LowCoutry Swampers
year of motor
Year of motor is irrelevant when concerned about pushrod length. The standard length is 9.59" and you can also get +.03" and -.03" lengths. Oil pressure is not static, rather it is always fluctuating, but the factory spec for a 360 or 390 is anywhere between 35-60 psi at 2,000 RPM. I've heard some people say that they only get around 5-10 psi in some of these FE motors. I'd be scared in that range.
year of motor
Scott, The design of the oil flow in the FE causes that problem. My fresh 352 does the same thing. I have let it idle for 20 min and the oil pressure dropped to near 0 and the engine got rather warm. Get it going again and the temp will come down and the pressure will go back up to abound 25.
John
jowilker
[link:www.ford-trucks.net/users/jowilker|Club FTE since 01 01]
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NC Truck Owners]
66F100s Rule
In the cool still quite of night you can hear chevies rusting away.
John
jowilker
66F100s Rule
year of motor
Scottlow, there should be casting #s on your block and heads that show what year the engine was made. IMO, the design of the oiling system is fine on the FEs, however, the execution by the foundry is less than wonderful. I would be nervous with 25 pounds. If you're interested, this is a fixable problem DF
year of motor
Scott, what makes you think the motor is not the original '70 motor?
The 360 was produced and installed only in light trucks from 1968 to 1976. Casting numbers will most likely do you no good in pinpointing a year. For example the block casting numbers C6ME or C8AE are found on most all 360 blocks from '68 to '76. These same numbers are also found on 390 blocks and 410 blocks. You will also find these numbers on some 427's and 428's. The "C" means 1960's and the second digit signifies the actual year in that decade, i.e. C6 represents 1966 and C8 represents 1968. Likewise, the letter "D" was used to identify components produced in the 1970's.
year of motor
Scott, if you jump over to the FE forum there is a thread about catastrophic engine failure, about an FE without the proper oiling mods done. jbhf250, with more computer skill than I have, has pasted my oiling mods into a reply. To do the whole job the engine would have to be removed, but if you are willing to pull the pan, you could do some of it. The rocker shafts could be dealt with with the valve covers off. DF
