Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Locking gas caps are stuck!!!
Old Jul 27, 2002 | 10:39 PM
samhihn's Avatar
samhihn
When I bought my dual tank van I didn't get the keys for the gas caps. I used a small pry-bar and had them off within 5 minutes. They are only used to keep honest people out. The top of the cap with the locking section just pops right off and then you can untwist the threaded section in the filler neck.
Old Jul 28, 2002 | 09:26 PM
rebocardo's Avatar
rebocardo
Yes, on others you can pop the top off and there are two small holes you can stick screwdrivers into and turn the holes at the same time to untwist the cap.
Old Aug 1, 2002 | 06:54 PM
cjcathey2002's Avatar
cjcathey2002
odd. i have ran both my tanks dry on a few occations, aux tank holds 19 gallons and the main tank holds 20.5 gallons.
1977 F250 460
C6 Hedman Headers
Dual 40 series
edelbrock performer
holley 4150
msd 6a and blaster coil
Old Aug 1, 2002 | 10:27 PM
Torque1st's Avatar
Torque1st
Posting Legend
On a 1977 F250 460 the Ford OEM paper repair manual lists:
19.2 on 133/138.8/155"wb aft axle tank.
19.3 or 17.5 on the in cab tank
20.2 on the 133"wb 4x2 midship
19.5 on 138.8/155" wb midship
There are other odd combinations up to 22.5 g on the midship tank also. All figures in U.S. Gallons.
Old Aug 5, 2002 | 11:21 PM
Jermafenser's Avatar
Jermafenser
Are you talking about the factory locking caps?
To open:
Turn key 1/4, and leave the key in that position then turn & pull the gas cap until it is out.
To lock:
Take the key out, and turn it all the way until it is sealed.
Old Aug 6, 2002 | 01:24 AM
mutant's Avatar
mutant
Hi lesliemacd
Happy that you problem is solved. I know that in this case you just needed the gas caps off, but one thing you might like to know is, that you NEVER put an petroleum based lublicant in a lock if you're not going to disassemble it for cleaning. The reason? Oil will attract dust and clog up the lock even worse over time, even if you prevent it rusting. Dust and oil will also act as
an abrasive and eventually wear out the locks components.
Instead, use a dry graphite powder or a pressurised graphite spray that uses a fast evaporating carrier.
Cheers
--Heaven will be inherited by every man who has Ford in his soul--
Old Sep 8, 2002 | 08:02 PM
theonlybull's Avatar
theonlybull
so your saying that i shouldn't use 10w-30 in the door lock on my truck every winter, after it freezes me out, and makes me walk to work??? i've only been doing it for 10 years....
Old Sep 13, 2002 | 01:02 PM
winfordr's Avatar
winfordr
I would have used a cordless drill and drilled out the lock.
I have combination locking caps on my vehicles. They have a pocket for spare keys inside. I never have to worry about locking my keys inside (unless I forget the combination).
Winford
Old Sep 14, 2002 | 07:16 AM
alanscott's Avatar
alanscott
moconnor603
15
Nov 26, 2016 09:25 AM
jgavac
18
Jun 28, 2014 09:27 AM
DieHardChief
Nov 5, 2013 10:41 PM
vwfreak
15
Jun 21, 2012 05:08 PM
ceetwarrior
13
Jun 1, 2004 05:46 PM
