Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Stock Intake Removal Tips?
Old Aug 2, 2002 | 01:37 AM
charlez's Avatar
charlez
Old Sep 14, 2002 | 01:43 AM
79CuZTuM's Avatar
79CuZTuM
Cant get the Stock Intake off my '79 460 c.i.d in my f-150 its the original motor with 185,000 on it so i am taking it down to rebuild it and make it a beast but i cant get the heads off to put my victor jr heads on it and my stealth but most important i cant get the heads off to pull the block to get the work done to it and only have an engine stand for a small block so dont wanna push it and drop my motor so any ideas on how to get that s.o.b off of there thanx
Title Changed for compatability with Garage Forum -Mod
Old Sep 14, 2002 | 07:16 AM
alanscott's Avatar
alanscott
I had that problem once. I used a wooden 4x4 that just fit across inner fenders. I set a little hydraulic jack on top of it and ran a chain over the top of the jack and bolted it to the carb studs. I put a little pressure on it and it didn't want to lift it off and while I was standing there wondering how hard I could go with out stripping the studs, it popped off. If you try this, be careful of stripping the studs or collapsing the inner fenders.
Old Sep 14, 2002 | 07:19 AM
classic79's Avatar
classic79
First make sure you have all the bolts out. Then at the front corner of the intake where it meets the head, use a long pry bar and hammer it under the intake to break the seal. You might have to use a smaller pry bar intially then work your way up. Once you do that pry that puppy up.
Chris
79 F-150 Lariat: Long-bed, 2wd, 460 (intake, headers, cam, early heads), C-6 (shift kit)
79 Mustang: 460 swap under way, balanced rotating assembly, forged pistons, truck rods, c-8 heads ported, Lunati solid lifter cam, more stuff...
98 Chevy Silverado ext. cab 4x4 (work truck)
95 Lexus SC300 (wife's baby)
