Potentiometer?
Old Mar 7, 2006 | 11:47 AM
tjbeggs's Avatar
tjbeggs
on second thought you need an ohm meter! don't just hook them up and hope i am right. it could fry something and that would make me feel bad!! let me think about this more and i will get back to you! i know others have used a pot for their 10k mod so maybe start a new thread with something like "variable 10k mod??" and see if that grab anybodies attention.
Old Mar 7, 2006 | 02:25 PM
turbostroke's Avatar
turbostroke
Originally Posted by VQ2Fast4U
Thats a bad pic, it has 3 connections. Which is whats im not understanding.
3 terminals.. 2 (usually the outside ones) are connected at opposite ends of a resistive element. The third one (usually center) acts as a wiper across the contacts that slides across the resistive element. In essence you are basically trying to use the pot as a variable voltage divider. The 12V input source will simply get divided to act like 2 individual resistors.
In a linear taper pot like the one you have purchased the output is generally the voltage at the point where the wiper contacts the resistive element..As PSnut said you are tricking the ICP to adjust based on "false" voltage readings.
Just make sure this pot is up to your task.. just as resistors have a load rating/capacity so to does a potentiometer.
guisepi
Jul 1, 2024 01:20 PM
mvedepo
6.7L Power Stroke Diesel
321
Mar 11, 2019 08:27 PM
moejr
Electrical Systems/Wiring
Dec 5, 2016 09:58 AM
Texas Bob
Aug 7, 2016 12:48 PM
bookem15
Oct 19, 2011 02:14 PM
