New Member, Having Problems.
Old Mar 5, 2006 | 09:35 AM
jrdelano's Avatar
jrdelano
Good Morning ,guys. Want to pick your brains. Went to start my '01 F-350, 7.3l this AM, and all she does is crank over and does'nt fire. Had her plugged in all night. Not bad over night here in Syracuse, NY temp. wise. But just do plug it in for easier AM starts. My guess is the glow plug relay. What do you think?
Old Mar 5, 2006 | 10:11 AM
PSNut's Avatar
PSNut
Did u get lots of white smoke? Your CPS may be bad too.
Nut
Old Mar 5, 2006 | 10:17 AM
t.j.g.'s Avatar
t.j.g.
u can jumper out relay and see if it starts or check the voltage drop across the relay contacts
Old Mar 5, 2006 | 10:24 AM
TXsnyper's Avatar
TXsnyper
My $.02 is the CPS.
Old Mar 5, 2006 | 10:32 AM
jrdelano's Avatar
jrdelano
Did not have any smoke, NUT
Old Mar 5, 2006 | 10:34 AM
jrdelano's Avatar
jrdelano
Well Snyper, thats what I would think too, but have just replaced that about 10 mo. ago.
Old Mar 5, 2006 | 10:37 AM
jrdelano's Avatar
jrdelano
I have'nt tried that, will try right now. TX T.J.G.
Old Mar 5, 2006 | 10:42 AM
jrdelano's Avatar
jrdelano
all I do is cross the two large posts with a scewdriver for 10 or secs with the key on Correct?
Old Mar 5, 2006 | 11:12 AM
chapguy's Avatar
chapguy
Yeps, do it for about 30 seconds if you don't mind a warm screwdriver. That way there's no doubt when you get in to fire her up. Be sure to only touch the two large posts (and it WILL get sparky for a second).
Old Mar 5, 2006 | 11:44 AM
jrdelano's Avatar
jrdelano
Hey Chapguy, Thanks for your info, but I'm having no luck firing up. Have tried twice and the same thing, it just sits there cranking. I did fire it up yesterday, stayed running for about 2 mins. then died. Got it re-started, but ran very pour, allmost like not running on all 8. Would not stay running without my foot on the gas. Could I have a fuel problem?
Old Mar 5, 2006 | 12:05 PM
clux's Avatar
clux
No smoke usually means no fuel.
How's your battery voltage/condition?
The injectors are electrical. If you have less than about 9 volts, the injectors won't fire.
Old Mar 5, 2006 | 12:10 PM
kawika's Avatar
kawika
Have you checked the oil level lately? Is the HPOP full? Whens the last time you changed the oil?
Old Mar 5, 2006 | 12:13 PM
jrdelano's Avatar
jrdelano
Clux, I don't have a voltage meter here at the house, put I will check all the connections. TX will keep you guys posted. I really thank you all for your input!
Old Mar 5, 2006 | 12:15 PM
jrdelano's Avatar
jrdelano
What does HPOP stand for?
Old Mar 5, 2006 | 12:16 PM
PSNut's Avatar
PSNut
HPOP= High Pressure Oil Pump
