fuel injector
Old Mar 2, 2006 | 08:22 PM
leadsled's Avatar
leadsled
fuel injector
i have a 96 psd and it started to run bad I had a diagnostics test run on it and it said that the number eight injector was going out. But I heard that you cant just change one out you have to change them all. Is this true and where can i get info on how to change it out
Old Mar 2, 2006 | 08:36 PM
barebackjake's Avatar
barebackjake
you can just change one, how many miles are on it?
theres some sites that have good injector r&r
swampdonkey dot biz has a very detailed write up on it. you can replace the injector or you can get them rebuilt. beans diesel performance does all my injector work
Old Mar 2, 2006 | 08:52 PM
leadsled's Avatar
leadsled
there is 182000 on it
Old Mar 2, 2006 | 10:37 PM
barebackjake
if the injectors havent ever been outta the truck i would go through them all for a reliability standpoint then you shouldnt have to worry about it again for another 182K
Old Mar 3, 2006 | 05:50 AM
1997F-350's Avatar
1997F-350
yeah i agree do em all and maybe have em built up a little too. chances are more will start to go soon also.
Old Mar 3, 2006 | 08:24 AM
DaBigTow's Avatar
DaBigTow
Did the test say #8 injector was bad? Or was it "intermittent or open circuit" on #8 injector? Engine sounds the same in either case. If the second one, it's likely that the harness under the valve cover is defective. I had #8 injector replaced under warranty at 80k miles, then had the same problem at 140k. turned out to be the harness. The old harness used a plastic clip to hole the connector to the injector; new one uses a metal spring clip.
Old Mar 3, 2006 | 11:48 AM
tjbeggs's Avatar
tjbeggs
if you give us a little more info we can help you diagnosis this better. is there a check engine light? if there is then you probably have an eletrical issue rather than a mechanical issue with an injector. the cylinder contirbution test is the only test that could tell you if you have a mechanical problem like the injector not firing or low compression. but if the CEL is one then you could ahve a bad injector but there are about 10 other things it could be also.
injectors aren't cheap so you don't want to just throw one in there and hope it fixes the problem.
Old Mar 13, 2006 | 07:46 PM
srpsdf250's Avatar
srpsdf250
My 96 psd started having the same problem today. Check Engine light comes on and engine gets real rough with a BIG drop in power. On 150 mile stop and go trip the light was on over half the time. I have a scanner but no codes were read. Truck has 261k miles and mpg has dropped from 18 to 15 over the past year.
How can I tell which injector is bad? Those puppies are over $350 each at Advance Auto!
Old Mar 13, 2006 | 08:06 PM
1997F-350's Avatar
1997F-350
with a cylinder contribution test... dont buy injectors from advance. have yours rebuilt for the price of 2 new ones.
Old Mar 13, 2006 | 11:44 PM
94 1/2 stroker's Avatar
94 1/2 stroker
Definatly Beans, you wont be disapointed!
halfbrit
Nov 19, 2015 09:39 PM
MauleOne
Sep 13, 2014 12:03 PM
smitty403
Mar 10, 2014 03:24 PM
swcollins
Sep 19, 2012 08:44 PM
youngster
Jun 23, 2001 07:31 PM
