Tail light problem
Old Mar 2, 2006 | 06:09 PM
bhebb's Avatar
bhebb
Tail light problem
I have got a 94 F150 XL and I have got no turn signals no four ways on the rear and no brake lights not even the cab stop light. I have checked fuses, brake light switch, and the flashers. They check out ok. I did not know if the turn signal switch might be the problem. Thanks for your help.
Old Mar 2, 2006 | 06:38 PM
SUPER6's Avatar
SUPER6
I Believe The Circuits Run Through The Switch.
Old Mar 3, 2006 | 07:54 AM
projectSHO89's Avatar
projectSHO89
Check fuse F13. If blown, it will take out all of these circuits.
If blown, you should suspect the cruise disconnect on the master cylinder to be leaking and shorting out.
Since the third brakelight is also out, the problem is not in the MFS since that light's power is not routed through the MFS but is direct from the BOO switch.
Steve
Old Mar 3, 2006 | 08:22 AM
Franklin2's Avatar
Franklin2
Steve
That's correct. I would check all the fuses and see if you have power at the brake switch green wires.
Old Mar 3, 2006 | 01:11 PM
projectSHO89
No need to check all the fuses, just check # 13 only.
This problem has been around for a long time in quite a few Fords, not just trucks.
Steve
Old Mar 4, 2006 | 06:36 PM
bhebb's Avatar
bhebb
Thanks for the help. I traced the problem to the multi function switch, it seems to be the problem. I checked the third brake light it had a bad bulb, It works fine. Thank again.
thatsrealnice
16
Jul 31, 2020 06:00 PM
waverous
Oct 10, 2016 10:10 AM
wrd0225
May 4, 2016 03:49 PM
Stuckinthemuddd
Apr 2, 2015 01:43 AM
aortizexcursion
Feb 20, 2014 01:04 PM
