1988 IDI No brake lights. Fuse good. Where do I start? There are two switches on brake pedal. Which is the switch for brake lights? I have turn signals.
How do you know the fuse is good? Did you try swapping it for another? (just double checking what you did, because sometimes they look good, but aren't).
IIRC, cruise brake switch would be vacuum on an 88, so start at the brake switch with wires, and try to trace which wire goes back to the fuse panel. Like Tom said, one of those wires should be hot at all times, if neither one is, it sounds like your problem is there.
If both switches have wires, then you'll have to trace both until you find where the problem is.
