I have an interesting issue with my brake lights that I would like a little input on from you guys and gals.
I have a 1978 F250 4WD that I am getting up and running. While checking lights and bulbs I noticed I didn't have a passenger side brake light (Driver's side is fine).
- Checked the bulb - it's fine
- Checked the current with a circuit tester - no current
- Checked the turn signal - works. (both turn signal and brake light share the same wire, so wire appears to be alright since turn signal works.
- Rechecked brake light again - no power
- Pierced the green wire with a tester light and I get pulsing turn signal only.
- Checked wiring plug and I'm getting electricity for all except passenger side brake light
So what I know - electricity is passing through the wire because I am getting turn signal - just no brake signal.
After following the "282 Gr" brake light wire on a wiring schematic, I find it runs to the turn signal switch. The switch does not cancel so I was planning on changing it anyway, but is my thinking correct - can my brake light issue be related to the turn signal switch?
After the Brake light switch (On the Pedal) it's first stop is in the turn signal/hazard switch(es) assemby. From there it separates into Left/Right Turns and Stop, Kinda like a trailer plug setup.
See if you get volts at the under column Connector? Ohm from there to the back if you hafta.
Reason: left turns, wat?
at the risk of beating a dead horse - also check all of your grounds. I had exactly the same symptoms a few months back and discovered that while the ground wire was great the actual socket-to-ground-wire connection was crap... in the front turn signal socket. Replaced that socket for a few bucks and suddenly my REAR signals and brake lights started working right. Based on my limited experience over the last few decades, I would say that probably 90+% of what I originally thought were switch problems on old cars turned out to be ground problems.
