I have 2003 E350, 7.3, Automatic Trans. must have the rear locked and need some advice.
In the Ford feature description table the rear have this describtion:
CODE: EGJAB non-limited slip rear axle.
Rear axle assembly code:EJAJJ - 6340LB(2876kg)rear axle asy.
final drive ratio 3.55 Code:EGAHD
This van will be used for street and icy roads as well as off road, What would you recommend to install and how to find the best best price for the parts.
Thanks.
