vin's again...
Old Mar 23, 2001 | 12:18 AM
quadna711's Avatar
quadna711
vin's again...
sorry to run this string again, but i am having a hard time finding out anything about my truck in the way of birthplace, axle ratios, etc. i remember seeing a list that had a link to a site where you punched in your vin and you could get back all the info on your truck...anyone still have that link? also, i checked the sticker on the inside of the driver's door jamb and it is blank along the entire bottom line (where the axle codes and other info is supposed to be). anyone seen that before? either way i tried to fire up the archive machine and/or the site search and had no luck with the vin or the axle codes. i sure appreciate any ideas. oh yeah, i already checked for the tab on either pumpkins - nothing other than the raised 44 and 60 on the front and rear. my vin is F26BNEH2853 thanks all
Old Mar 23, 2001 | 06:32 AM
jowilker's Avatar
jowilker
vin's again...
CB, Did you check the tech articles on this site. Stockman has a site for you 67 owners. Try doing a Google search and key in Ford Vin Decoder.
You boys give up to easily.
John
jowilker
[link:www.ford-trucks.net/users/jowilker|Club FTE since 01 01] My FTE Page
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NC Truck Owners] NC Ford Truck owners group
66F100s Rule
In the cool still quite of night you can hear chevies rusting away.
Old Mar 23, 2001 | 08:24 AM
fozzy's Avatar
fozzy
vin's again...
711, give me the codes from your driver side door jamb, and Ill let you know the birthplace, axle ratio,trans etc (although engine,axle may have been changed)
https://www.ford-trucks.com/dcforum/User_files/3a9df0394b631ce6.gif
77'FORD F150 XLT 400
Old Mar 23, 2001 | 06:00 PM
quadna711's Avatar
quadna711
vin's again...
fozzy, i would give you the codes, but the label is blank other than the front and rear weight limits, gross, and tire pressures. i'm not sure why this is, maybe it was salvaged at one time or it was just not printed well. i even cleaned with glass cleaner trying to raise the letters - just seems like they were never there to begin. i think i'm going to try john's advise and hit the google search. and john, it isn't that i gave up to easily, only that i'm not that savvy when it comes to surfin' the information superhighway. thanks much for the advise
Old Mar 23, 2001 | 06:52 PM
sparky's Avatar
sparky
vin's again...
This is what I got from the VIN.
Model Year: 79
Series: F250 - 4x4 Pickup
Engine: 6 Cyl, 300ci (4.9L) 1bbl
Assembly Plant: Norfolk
Transmission: No code selected
Front Axle: No code selected
Rear Axle: No code selected
Sparky
Old Mar 24, 2001 | 12:45 AM
quadna711's Avatar
quadna711
vin's again...
thanks sparky and everyone else too. i think i'm just going to give it the chalkline on the driveshaft method (thanks john for the directions on that) and roll it down the driveway. later all
Old Mar 24, 2001 | 06:13 AM
jowilker's Avatar
jowilker
vin's again...
Hoss, I recommend that, because it doesn't matter where the truck came from, there have been too many through here that have had, and others could have had the parts changed out. The only way that you can know for sure is to check it for yourself. Be sure to have a friend with you, just in case things don't go as planned. We want you here with us all in one piece. ;-)
John
jowilker
66F100s Rule
Old Mar 24, 2001 | 09:12 AM
dinosaurfan's Avatar
dinosaurfan
vin's again...
revhead64
May 8, 2021 11:16 AM
F2501972
20
May 28, 2014 09:19 AM
jggearhead
6.7L Power Stroke Diesel
Aug 3, 2011 03:36 PM
brd7666
Feb 1, 2011 01:15 PM
bell-vins
Jan 24, 2009 04:34 PM
