connection on MAF sensor
Old Feb 28, 2006 | 04:31 AM
jmagers's Avatar
jmagers
Can someone explain how I would go about repairing a broken wire on the MAF connector?
Old Feb 28, 2006 | 04:44 AM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
I'm not sure on the exact details of your broken wire; I suppose if the wire is cut (broken) a small distance from the connector then soldering and using shrink wrap will be just fine. On the other hand, if the damage is within the connector then a replacement will be in order. New in the box connectors with a pigtail are available.
Old Feb 28, 2006 | 04:51 AM
jmagers's Avatar
jmagers
Thanks for the quick reply, the wire is broke flush with the connector
Old Feb 28, 2006 | 04:55 AM
Torque1st's Avatar
Torque1st
Posting Legend
I purchased one from Carquest. All you need is the same terminal arrangement. Wire color does not matter.
Old Feb 28, 2006 | 05:39 PM
jmagers's Avatar
jmagers
Torque1st, can I ask what it cost you?
steve83
Dec 6, 2002 02:22 PM
dship
15
Sep 29, 2002 12:08 PM
skeoch
Jul 26, 2002 11:52 PM
daspud
Jul 18, 2002 06:17 AM
Thebull
Mar 10, 2002 09:59 PM
