Two MAF Questions
Old Mar 10, 2002 | 04:23 PM
Thebull's Avatar
Thebull
Two MAF Questions
Old Mar 10, 2002 | 09:19 PM
El Guapo's Avatar
El Guapo
Two MAF Questions
I recently bought a '96 F-250 460 with a factory MAF system. According to a title search, the original owner bought it in California.
How well does the MAF system accomodate engine mods like headers, cams, or slight compression increases?
Are the MAF air intake sensors interchangeable between different engines? For example, is the MAF in my vehicle interchangeable with one from, say, a 200 F-150 5.4, or a Lincoln 460?
For bonus points, can someoene explain in 29 words or less how the so-called 'learning process' in the EEC-V system works?
Thanks, Mr. Ford!
Old Mar 10, 2002 | 09:59 PM
canzus's Avatar
canzus
Two MAF Questions
Snip...
Very well, if you disconnect the battery while you're
doing the mods, the computer will relearn how the run
well all on its own...
>Lincoln 460?
The Lincoln never had the 460 with MAS FI, so that's
a null question...
>works?
In 29 words or less?? Maybe...
The ECU has a default program, with minimum timing,
fuel, and mixture values. While running the vehicle
those values are updated constantly, until the engine
is running within the parameters setup from the factory,
which is why you need a custom chip burned when you
exceed some of the parameters...
Is that clear enough??
Steve & the Rockette
'63 F100
'68 F100
'72 Capri 2L
'73 Capri 2.6L V6
'73 MG B GT 2.6L V6(Ford)
'98 Contour SVT 2.5L V6 (Mods)
'01 ZX2 (No Mods yet)
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
