460 MAF
Old Jul 24, 2002 | 11:43 AM
skeoch's Avatar
skeoch
460 MAF
Old Jul 26, 2002 | 09:20 PM
BBF0RD's Avatar
BBF0RD
460 MAF
Does a late model 460 (EEC-IV) use a Mass Air Flow system
If so is it possible to convert a 89 460 (EEC-IV) from speed
density system over to a MAF system
Old Jul 26, 2002 | 11:52 PM
Paarrothead's Avatar
Paarrothead
460 MAF
Well, yes, I guess...The 1996 and 1997 California F-250s and F-350s with 460s came with MAF systems and the EEC-V ECU. I own one, bought it used from someone that moved here from the left coast.
The 49 state versions were all speed density. Also, the Cal versions had 24# injectors, did not use exhaust manifold air injection, did not have an engine air pump, did not have that restrictor usually found inthe intake air pipe, and they used a single king sized 3" in-and-out catalytic about 2 feet long.
Too bad they didn't build them that way in all 50 states.
I have no idea what might be involved in doing the conversion, but all the parts you might need are off the shelf Ford truck parts (or off the junkyard).
I use my F-250 mostly for hauling and towing, only today I drove 250 miles hauling 4 tons of hay on a 2 axle flatbed with it.
Hope I helped, let me know if you need more information.
-Bill in Colorado
Two Easters Ranch
1996 S/Cab F-250 4x2 Long bed 460
E4OD auto, 10.25" 4.10 posi, Air-Lift suspension,
homebrew cold-air intake w/K&N filter, modified ignition advance curve, Edelbrock 2x61 mm throttle body, Bosch Platinum +2 plugs, Champion truck plug wires, L&L 4 into 1 headers, .060 milled heads,
3" exhaust system, cat & Flowmaster 70, modified MAF meter, Michelin LTX 265/75/16E, Mobil 1 10W-30, Red Line D4 ATF, Red Line 80W-90 in axle. Reese class III hitch. 5,700 lbs empty.
{E\...F}
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
