highboy or standard frame
Old Feb 27, 2006 | 06:40 PM
460man's Avatar
460man
which frame do u think is best, highboy or standard frame. im going to swap my f150 body over to one of the 3/4 frames but which one, also is it hard to move plates on the axles, since the highboys are narrower. its a 77 frame
Old Feb 27, 2006 | 07:13 PM
Jmudder79's Avatar
Jmudder79
they are both good frames. You would have to drill new mounting holes to put any standard frame bodys on it. Its not too hard. Also i think the high boys have different rear leaves. something like 1 3/4" width leaves. Not too common if you are looking to lift it. Although any good leaf spring shop should be able to make you a custom set. May be a little more expensive than standard width leaf spring lifts. Just some things to consider.As far as the axle plates just grind the weld off along the tube and whack 'em with a hammer. Just make sure you keep them centered and even and have a good, competent person weld them back on.
Old Feb 28, 2006 | 09:11 AM
highboy390fe's Avatar
highboy390fe
Yes the Highboy rear leaves are 2.5 instead of 3 inches.
Old Feb 28, 2006 | 05:39 PM
Jmudder79's Avatar
Jmudder79
I was close.
Old Feb 28, 2006 | 07:13 PM
buzzbait65's Avatar
buzzbait65
things will be easier with the 78-79 250 frame, from axle widths, body mounts, gas tank options, steering, etc....
btw, all three of my highboys had 2 1/4" rear springs
Old Feb 28, 2006 | 07:22 PM
460man's Avatar
460man
leafsprings
could i make the highboy leafs fit on my f250 frame then. like put a spacer on the bolts
Old Feb 28, 2006 | 08:15 PM
buzzbait65's Avatar
buzzbait65
i dont see what it would hurt, it is only about 3/8" per side of the spring eye. i take it you dont have the 3" wide springs for that frame......you will also need to address the u bolts and spring plate width issues
Old Feb 28, 2006 | 08:19 PM
460man's Avatar
460man
leafsprings
no i have the springs i just want the added heigth of the hgihboy leaf springs
Old Feb 28, 2006 | 09:17 PM
michaelbarry's Avatar
michaelbarry
..I thought the only thing that made the highboy sit higher was a 2 inch block. Guess I was wrong.
Old Mar 1, 2006 | 06:21 AM
buzzbait65's Avatar
buzzbait65
the highboy springs would probably have a little more height (more arch and more leaves) depending on what lift height you want, a rear shackle flip helps too.
the highboys i have owned have all had 4" blocks, they really are just a completely different chassis set up than the 77.5-79 f-250's (4x4's)
Old Mar 6, 2006 | 06:31 PM
bloodhound51's Avatar
bloodhound51
mine has 4 inch blocks 2.5 inch width on the rear springs 3 inch in the front my frame flexes really nice on rocks and such be carefull because th ehighboy frame is only 35 1/4'' wide and most gastanks will not fit in between the rails and if you do find one that will fit the rear axle will bump it when the springs flex i like the gastank in the cab myself.
2 cents
breezesboy
Oct 27, 2014 03:42 AM
Vinford
Feb 9, 2009 11:44 PM
okwaho1650
Jan 29, 2009 11:42 PM
sunnyb
Jan 18, 2006 06:20 PM
