Modular V10 (6.8l)
V10 Tune Up Question
Old Feb 28, 2006 | 07:30 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Right on Cap... these motors are EASY to change the plugs. If I wasn't ****, I could have had it done within 1-2 hours.
Try changing the plugs on a mid 80's 5.0 Mustang with the air injection and AC in the way
Old Feb 28, 2006 | 01:41 PM
captchas's Avatar
captchas
Guest
hay art
how about a 69 merc cyclon with a 428 in it. to change plugs r andi motor.i'll do my v10 any day, even over doing my wifes jeep liberty that little sob v6 took 5 hours to change the plugs as every one was seizeing in the head at 30k, 60k plugs sure after i'm 6 feet under.
Old Feb 28, 2006 | 04:40 PM
Bob Gervais's Avatar
Bob Gervais
I'm getting ready to do some maintenance on our newly acquired 2000 X with the V10. This thread is very useful, it's good to read from the guys who have done it, what the best options are for parts and fluids.
I do have one question relating to plugs though. In my past experiences with my wife's former Taurus, it ran like junk on anything but Motorcraft plugs and wires. Does the same hold true for the V10? My local Autozone doesn't have Motorcraft plugs, but they do have Autolite plats. Are the Autolites OK to use?
Old Feb 28, 2006 | 05:03 PM
krewat's Avatar
krewat
I've used the Autolites in my modulars and they were perfect. I used Motorcraft in my V10 just because I didn't want any problems. I personally think the Autolites are the same plug. Others here are more cynical about that than I am, so maybe you should just go out of your way to the the MC's. Guys?
Old Feb 28, 2006 | 06:20 PM
captchas's Avatar
captchas
Guest
i too use autolight in my fords and the wifes dcx. and have never had a problem with them.lets also remember autolight was ford at first till god old uncle sam said you are causeing a monopoly and ford sold the autolight brand/name. as to who makes motorcraft for ford now. i don't know for sure but agree with art , as i to can't tell them apart with out the name being seen.
i don't see why you can't use them as long as it's the factory look alike plug. go to walleyworld and get your self a few motorcraft fl820s oil filters. 5w20 or 30 oil as per the owners manual for your x, just stay as close to factory as possible at the speced times ie, miles or months of servicewhat ever hits first.
if your doing those plugs your self get a tube of never seize for the threads new plug boots for the coil packs and a inch pound torqe wrench to torqe the plugs to the factory spec for them . before you pull them out use some air and blow out around the plugs to make sure nothing falls into the hole.
if you don't have the new heads "i think you don't 2000 " be carefull with tighting the plugs thats why the torqe wrench is so much needed.
Old Feb 28, 2006 | 06:30 PM
Bob Gervais
Thanks very much for the advice guys! That was quick!
I'm planning on using the '03 up plugs, with the longer length of threads. Even with the older heads, the longer thread engagement can't hurt.
I've got a jar of antiseize, I always use it on plugs, even in my cast iron headed Suburban.
I'm obsessive compulsive about fluid change and service intervals. Having this truck has made me worse, but that's a good thing! I just can't believe how inexpensively we were able to buy this truck, and I want to keep it in top shape for a long time to come.
Old Feb 28, 2006 | 09:37 PM
captchas's Avatar
captchas
Guest
you can't use the latter ones in a early. the threads are way different. unless you want to convert the heads with the newer inserts from these 2 companys
http://fulltorque.com/sparkplug.htm ford full thread inserts
http://www.timesert.com/html/triton_repair.html
they are costly for the kit but when a plug blows out of a early head it beats the dealer rip off of changeing both heads over. the timesert also shows how the plugs are different.
Old Mar 1, 2006 | 02:39 AM
Bob Gervais
Thanks for the information, and the links. I was told that the latter spark plug was a direct replacement, good thing I mentioned it here before trying it out!
To my knowledge, I don't have any damaged plug holes, so I'll stick with the stockers until problems come up. If I find any damaged holes, I'll just buy the repair kit and do all of the plug holes.
Old Mar 1, 2006 | 03:15 AM
captchas's Avatar
captchas
Guest
shucks bob
i thaught i was a early up or up all night person. 0413 and your on line.
Old Mar 1, 2006 | 03:24 AM
Bob Gervais
Yep, I usually don't get quite such an early start, but I have some road jobs to do today, and about 4 hours total travel time. Can't hurt to get on the road before the rush hour hits!
Old Mar 1, 2006 | 03:28 AM
captchas's Avatar
captchas
Guest
esp. if you have to use i95 out of where you are or down here by me. yuk
Old Mar 2, 2006 | 12:18 PM
pjl42's Avatar
pjl42
Talking
thanks for all the help...i really appreciate it!!!!!
Old Mar 2, 2006 | 04:00 PM
  #28
Bob Gervais
Actually I was on 95n, then 93n. I hate that trip....
Bubba Jones
1978 - 1996 Big Bronco
Mar 29, 2012 03:01 PM
moose_j9
Apr 28, 2011 09:14 AM
mrad
Nov 6, 2009 12:52 AM
PW01
1983 - 2012 Ranger & B-Series
Jun 30, 2008 10:55 AM
Myckel
Apr 19, 2006 09:01 AM
