Kill Switch
Old Mar 26, 2001 | 07:30 PM
weldman's Avatar
weldman
Kill Switch
I know this thread has probably been discussed before, but my search turned up nothing.
What is the best way to rig up a kill switch?
Where have you mounted your actual switch?
What is the best type of switch? Just a regular stainless toggle switch?
What is the moniker for the switch I want? SPST? DPDT? etc.
I've been told that you have to splice the orange wire on the starter relay that goes to the distributer.
Any more to add?
Thanks,
Matt
1978 F250 Ranger 4x4 - 351M
Old Mar 26, 2001 | 11:04 PM
weldman's Avatar
weldman
Kill Switch
Nobody has a kill switch hooked up?
Also, where should I mount the switch itself?
Matt
Old Mar 27, 2001 | 12:51 AM
elsmith's Avatar
elsmith
Kill Switch
I have an electric fuel pump on mine and I am going to put a toggle switch on that and if some one tries to take it, it will only run until the float bowl is empty. Where to mount the switch you can mount it anywhere like make a bracket and mount it under the seat or any place that you can think of where no one will look. Eric
Old Mar 27, 2001 | 02:15 PM
rlbertrand's Avatar
rlbertrand
Kill Switch
Where to put the switch is up to you - I put mine under the hood on the back fire wall in a small black box that flips up. The hinge is on the inside so it looks like just another piece of electical equipment.
Used a high amp (very heavy duty) on/off so I did not have to worry about it being over loaded and ran ignition power through it.
Crank all you want - without the switch on you get no spark.
The MSD ignitions have a method also.
Old Mar 27, 2001 | 02:30 PM
weldman's Avatar
weldman
Kill Switch
What rating of switch should I use??
Did you hook it up like I am proposing? (orange wire to distributor?)
Matt
Old Mar 28, 2001 | 01:57 PM
weldman's Avatar
weldman
Kill Switch
I guess that I will just go get a switch and see if I can splice the orange wire and see if it works!
Matt
Old Mar 30, 2001 | 09:16 PM
Steve_Uzi's Avatar
Steve_Uzi
Kill Switch
I recommend putting the switch inline with the 12v going to the coil. But the orange wire will work to.. the only thing is you should 'dress' the wire going to the switch so it looks like it Belongs....
Uzi... Yamaha Sleds, Honda Bikes, and Ford Trucks....
Old Mar 30, 2001 | 11:29 PM
dust3's Avatar
dust3
Kill Switch
miihere24
May 19, 2013 01:01 AM
bigred66
Apr 15, 2011 02:45 PM
tamaleman
Nov 25, 2007 11:45 PM
racinghoss
16
May 10, 2003 06:55 PM
weldman
Electrical Systems/Wiring
May 22, 2001 08:23 PM
