Valve line modulator boost for E4OD tranny
Old Feb 24, 2006 | 07:34 PM
Keepitrunnin's Avatar
Keepitrunnin
Anyone installed one? I am trying to smooth out the shifting in my "93 4X4 5.0. It is shifhting hard. Is this a possibility & how difficult to install. I know enough about tranny's to get into trouble, but I don't want to spend 3K for a new one. Any help will be appreciated.
Old Feb 24, 2006 | 08:54 PM
quicklook2's Avatar
quicklook2
so trans is on the way out and you want to mess more with it?
change fluid, filter and drain convertor and use good new fluid and put in lucas trans treatment. imho
Old Feb 24, 2006 | 09:10 PM
MRL123's Avatar
MRL123
Also, don't forget that sometimes hard shifting can be caused by dirty wiring harness connections at the tansmission, a bad VSS sensor on the diff. or a bad TPS. What quicklook2 says makes sense - I wouldn't want to compound the problem by upping the internal line pressures and making the tranny shift even harder. Troubleshoot the easy stuff first.
Cheers!
Mike
Old Feb 25, 2006 | 08:06 AM
Ford_for_Brains's Avatar
Ford_for_Brains
just my experience, i'm no tranny man, but my 94 f-250 has the e4od behind the 460, and when it started shifting hard it was only 3 months tops before the intermediate sprag took permenant leave via a big hole in the left side of the transmission case. on a brighter not, they're not 3000 unless you plan to buy brand new, i sell remans w/upgrades & converters for around 2-ish.....if you can get my contact info from the moderators contact me sometime, i wont post it here for fear of getting in toruble
Studawg
Apr 10, 2012 02:06 PM
john8403
13
Nov 8, 2009 04:18 AM
littlefuzz
Apr 25, 2009 02:18 AM
4x4 VANMAN
Feb 6, 2006 11:38 PM
aunchman
Aug 6, 2002 06:06 PM
