Tap size for pyro probe??
Old Feb 24, 2006 | 05:57 PM
jtharvey's Avatar
jtharvey
I ordered up an Autometer pyro kit from Garrett at BCPD (by the way --> look for a company name change coming from him soon!!), and headed off to the store to purchase a tap for the manifold. Ran into 2 taps, not sure which one is correct. 1/8"-26 & 1//8"-27, both NPT taps. Which one do I need?
Old Feb 24, 2006 | 06:32 PM
the1mg's Avatar
the1mg
1/8-27 NPT is what you need........
Old Feb 24, 2006 | 06:41 PM
the1mg's Avatar
the1mg
Just a suggestion...if your detail oriented (or **** as friends call me ), thread the tap in about half-way the length of the threads, then and start fitting (one complete rev at a time) for proper depth placemant of the probe. It should be fitted at 6-7 thds. down from the wide end of the tap.
Old Feb 24, 2006 | 06:47 PM
jtharvey's Avatar
jtharvey
Thanks for the info and the tip. I tend to be "detail oriented."
Old Feb 24, 2006 | 11:34 PM
generalee31184's Avatar
generalee31184
Just finished up my autometer guage install/ dp chip and just got back from a test run. Yes you use the 1/8-27 with a size R drill bit. I just bought that stuff yesterday. Truck ran like a raped aped when the turbo kicked in. The only thing Im not really caring for is that it seems there is a lagging period before it gets up and goes, I dont know if it is normal or what. It seems like a dog till about 17-1800 rpm, then Holy sh**!!!
Old Feb 25, 2006 | 01:50 AM
jtharvey's Avatar
jtharvey
A size R drill bit? Help me out here. I've never heard of a size R.
Edit: Ok. I found out that a size R bit is 8.6106mm or .339" but where do I get one?
Old Feb 25, 2006 | 06:42 AM
generalee31184
There is a such thing as letter drill bit sizes, they are all that more closer to the size that is needed for the hole. I went to my local Fastenal store and said I need a drill and tap for this 1/8" NPT fitting and they looked in the book for the tap and it gave what size drill to use with that tap (size R drill). I dont know if you have a fastenal where you are but here, it is a store that sells all kinds of tools, piping, shop supplies, specialty items. They are most shops local supplier for hardware and whatnot around here.
Old Feb 25, 2006 | 08:50 AM
jtharvey's Avatar
jtharvey
Thanks!! Looks like I'll be doing some searching. I'm learning new stuff here all the time.
jdenny21
6.7L Power Stroke Diesel
Jan 26, 2013 01:31 PM
Heiny_F350
Sep 13, 2012 07:14 AM
spunks00
Apr 7, 2010 01:44 AM
highboy390fe
Feb 24, 2008 04:47 PM
cads03
Feb 1, 2006 12:24 PM
