Sponsored by: Kumho
suspension ?
Old Feb 23, 2006 | 04:26 PM
custom1's Avatar
custom1
Red face suspension ?
I have a 1974 f-100 2wd. and i just noticed something, and dont know what its called and thats what i need help with.
the arms which come from front axle mounted under each coil spring and extent back toward cab and mount to frame by a bracket near cab mounts with rubber bushings either side. The rubber bushings on the driver side are completly gone allowing the front axle to move back and forth 2-3 inches as i roll the tire back and forth.
I believe all i have to do is replace the rubbers but i dont know what to order or ask for. I feel kinda ignorant but i guess thats why we have this place huh?
Could anyone help me know what i need and any tips or extra info needed to repair this?
Old Feb 23, 2006 | 07:58 PM
Hyperactive460's Avatar
Hyperactive460
i believe they are called " C " bushings......
Old Feb 23, 2006 | 09:54 PM
thesprocket26's Avatar
thesprocket26
C bushings are on 4x4s. They are radius arm bushings. Polyeuethane ones are like $30 for both sides (4 pieces)
Old Feb 24, 2006 | 01:55 AM
custom1's Avatar
custom1
Thanks, Can these bushings be put on by removing the nut and pulling arm forward and out of the bracket? or will i have to dissassemble the arm from the front end also? I've taken the nut off and pulled forward on it a bit but it got dark on me too quick. and it acted like it was going to be tough pulling the front end forward enough to clear the threaded end through the bracket so i couild install the inner bushing. Ill try again after work today.
Old Feb 24, 2006 | 04:58 PM
thesprocket26
I really don't think you can pull the radius arm out of its hole. You have to disconnect it from the Ibeam or take off the I beam all together.
Old Feb 24, 2006 | 05:24 PM
custom1's Avatar
custom1
I just finished the drivers side and it wasnt a pretty site. I was able to pull it foward and out but i dont think i will do the passenger side that way. It was too much stress on things i think. But ive test drove her and notice nothing but improvement. much more stable ride it seemed and seemed to steer a bit tighter. I took her up to 70 and felt no problems and hard breaking same result. so i guess she's ok but i had to winch the front end foward and still just barely cleared. the rubber break line was to its max. Heck i dunno i may do the passenger side that way too i dunno. Im sure its not recommended. Thanks tho
Bart
Old Feb 25, 2006 | 10:23 AM
Hyperactive460
thanks for correcting me, it's been a while since i've worked on a 1/2 tons. i usually stick with the 3/4 tons.
MontanaEE
Aerostar
Dec 16, 2013 08:47 AM
wadar1969
Dec 29, 2010 12:54 PM
bleeds blue
24
Oct 13, 2009 09:07 AM
hivolt5.0
Jan 19, 2009 07:36 PM
rswhitmore
Jun 22, 2006 10:02 PM
