Speedometer
Old Feb 22, 2006 | 03:25 PM
randrade44's Avatar
randrade44
Smile Speedometer
Howdy; need your help to determine which part I need to replace:
I have a 1993 f250 4x4 with a 7.5l and E40D.
The speedometer works fine until I hit 60 mph and then it goes all over the place. I recently replace the VSS sensor in the rear of the Diff, becuase the speedometer was not working and the trans was shifing hard. By replacing this, my speedometer began to work just fine while driving below 60 mph however above these speed it goes wild. The transmisson continues to shift hard (althought I do not mind) and the crusie control over 60 does not work. I checked all the internal and external fuses and all are "OK".
Do you think I need to replace the gauge cluster or the PROM or something esle I'm missing.
Look forward to your help.
Old Feb 22, 2006 | 03:32 PM
quicklook2's Avatar
quicklook2
any codes?
reset computer by disconnecting battery.
did you replace rear end fluid?
did you clean ring around rear gear? that is what the ford manual says to do.
Old Feb 22, 2006 | 04:17 PM
randrade44's Avatar
randrade44
any codes?
The good news is that there are no codes.
Perfect I'll go ahead and reset computer.
I have not replace the rear end fluid..come to think about its pretty dirty...I'll do that, it needs it anyway.
Do you mean the ring tone? if so, I have not cleanned it, but excellent advice. I will clean as soon as change the rear diff fluid. I guess it makes sense; becuase the faster you go the more fluid you kick up onto the ring and if it is dirty, it will affect the sensor by convering it with dirty fluid.
Thank you bud; I'll let you know how it goes.
Old Feb 23, 2006 | 10:10 AM
randrade44's Avatar
randrade44
following up
ok; I was busy last night but was able to complete my homework of changing the fluids and cleaning the ring tone and resetting the computer. However, I'm still getting the same symthoms; speedo works well under 60mph, but continues to go wild over 60.
Also, no codes, engine light or Transmisson errors...any ideas?
Old Feb 23, 2006 | 01:12 PM
quicklook2's Avatar
quicklook2
well, just do not go over 60mph!
when i get home tonight i will go through my manual and see if i can figure something out for you.
Old Feb 23, 2006 | 01:21 PM
randrade44's Avatar
randrade44
It's kind of like going to the Doc. and let them know that it hurt when I do this ____ and the doc says: just don't do that and it wont hurt... I like it.
I'm just kidding bud; I certainly appreciate your help.
Thanks
YooperUno
2009 - 2014 F150
Oct 9, 2013 10:15 AM
boarhawg
1997 - 2003 F150
Apr 7, 2011 10:34 AM
429poweredf350
Nov 24, 2010 03:01 PM
hittman1422
Apr 3, 2009 05:34 PM
StrongRepublican
Feb 15, 2007 01:04 AM
